06-19-2011, 10:18 AM   #1
patrick9's Avatar
exif files attachment
I was checking the exif files on photos I uploaded today. when I resize the photos in elements 9 and upload the photos the file info is the created date( when I modified the photo) but the date taken does not come with it. is there a way to attach that part of the file? It is on the photo in it's folder but not here on this web site. I do not see a way to resize the photos in my pentax utility 4 program . thanks
06-19-2011, 09:59 PM   #2
I'm no expert but two things might be happening. Firstly if you're using the PS 'save for the web' function, it strips EXIF info. The other one is the site you're loading the file to might be changing it. If you are using 'save for the web', you can maintain the EXIF info by doing a 'save as' instead.
06-19-2011, 10:36 PM   #3
QuoteOriginally posted by patrick9 Quote
In PDCU4 (the Pentax Software) use File | Save As | Select "Change Image Size" in the Save As dialog box and then enter the new image size. 800 pixel for width should be ok for here but I think you can go to 1024 before the upload resizes it more.
That might not fix your date issue - I'm not sure if the upload feature here alters the date to modified.
Also make sure your Pentax software is up to date.
camera, date, exif, file, files, pentax help, photo, photography, photos, resize
How to batch rename files after files imported and tagged in Photoshop Elements raider Digital Processing, Software, and Printing 5 03-14-2013 10:36 PM
Software to rename/move files based on EXIF data, etc? archaeomanda Digital Processing, Software, and Printing 2 10-23-2010 08:41 PM
Kx viewfinder attachment? rotisiao Pentax DSLR Discussion 2 12-02-2009 04:53 AM
PDF file attachment FHPhotographer Site Suggestions and Help 3 08-24-2009 10:02 AM
Error Can not delete attachment ismaelg Site Suggestions and Help 3 08-15-2009 07:04 PM
All times are GMT -7. The time now is 05:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
