06-19-2011, 11:41 PM   #1
Kx-Rick's Avatar
First Dopey Question....
I am having fun learning about all the different things I can do with my new K-x, but
my first question is this:
When using a manual focus lens in most of the manual modes, the camera will always ask me to set the focal length before taking pictures. If I am using my
135mm Super Albinar do I set the focal length to 135 and so on for the different lenses?
Hope this is not a dopey question....
Thanks in advance!
Rick
06-20-2011, 12:11 AM   #2
Ash
Community Manager
Ash's Avatar
Yes, that focal length is what the camera uses to appropriately apply shake reduction.
06-20-2011, 12:37 AM   #3
Kx-Rick's Avatar
Aaaaaah..........
so if i use my 500mm tele lens......input 500mm focal length..........135 for135..
and so on.
Thanks so much
06-20-2011, 05:44 AM   #4
Docrwm's Avatar
QuoteOriginally posted by Kx-Rick Quote
Aaaaaah..........
and so on.
Thanks so much
Correct. Its one of the big advantages of the Pentax system using in-body shake reduction instead of lens-based image stabilization. Means we have shake reduction even for old lenses
06-20-2011, 08:47 AM   #5
RioRico's Avatar
Good, you didn't fall into the crap.factor fallacy! The SR'bot wants to know the lens' actual focal length, or as close to it as possible.
What to look for next: If you use a teleconverter with a lens, enter the multiplied focal length. So if you had a 50mm lens with a 1.4x TC, you would enter 50x1.4= 70mm (if possible -- 75mm is close enough). For a 50mm lens with a 2x TC, you would enter 50x2= 100mm. Et cetera.
This works for all primes. Manual zooms are another matter. For best results, enter the focal length you are using. But if you zoom a lot, that gets tedious. Someone here posted a formula for approximating the best entry:
(2 * min * max) / (min + max)
where min is the zoom's minimum focal length, and max is its maximum. Of if that's all too tedious, just shoot manual zooms in bright light with a fast shutter and turn SR off. That's how we did it Back In The Day. If we had zooms, of course. Newfangled gadgets...
camera, dopey, length, pentax help, photography
FA 28-70/f4 question TTQ225 Pentax SLR Lens Discussion 6 11-29-2009 03:23 AM
K7 question dafiryde Pentax SLR Lens Discussion 12 08-14-2009 10:18 AM
K7 question dafiryde Pentax DSLR Discussion 5 07-17-2009 06:05 PM
Got a Question Wildnsyko General Talk 3 07-02-2009 05:17 PM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 08:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
