06-21-2011, 05:24 PM   #1
pcarfan's Avatar
Help!...Aperture setting making no difference.
This is a P/K mount Kiron lens (No 'A' setting).
When I twist the aperture ring I can see the aperture blades opening and closing.
Then when I shoot with the lens in Av mode it is metering fine, however when the aprture is changed it makes no difference what so ever like the aperture blade being stuck wide open. The iso stays the same, the shutte speed stays the same and even the histogram is identical from f2 to f16, but I can see the aperture blades close...what is going on ??????????
I've had a loooong day and I am exhausted, I am pretty sure I am missing something?
Auto EV compensation is OFF in the menu.
06-21-2011, 05:30 PM   #2
This question was asked recently and can be found here:
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/148873-k-x-manual-lens-av.html
06-21-2011, 05:31 PM   #3
See also this thread: https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
Note that Av mode can only be used with takumars, not M/K lenses. For metering in M mode, see the instructions.
06-21-2011, 05:32 PM   #4
I am having trouble understanding the situation. Is the histogram remaining the same despite the image darkening as a consequence of the smaller apertures?
06-21-2011, 05:44 PM   #5
QuoteOriginally posted by pcarfan Quote
Manual (M non A type) lenses only work in M mode.
06-21-2011, 06:02 PM   #6
pcarfan's Avatar
QuoteOriginally posted by mccarvindh Quote
No the images looked the same eventhough I was physically changing the size of the aperture, what I couldn't understand is how could the brightness of th image stay the same when the iso and shutter are the same and the aperture is changing (the actual size of the hole changes), but I presume the picture is taken with the aperture fully open irrelevant of where it is set for M lenses.
06-21-2011, 06:02 PM   #7
pcarfan's Avatar
QuoteOriginally posted by jellyfish26 Quote
QuoteOriginally posted by JeffJS Quote
Thank you
aperture, blades, lens, pentax help
Verifying that old Pentax-A prime lens (setting aperture) works ok robroy Troubleshooting and Beginner Help 3 02-16-2011 02:45 PM
I think in this case, the camera body is making a big difference. sjwaldron Pentax DSLR Discussion 11 10-26-2010 01:50 PM
Making a slideshow w/ Aperture question..... UpNorth Digital Processing, Software, and Printing 4 05-06-2010 08:23 AM
The aperture difference....or is it??? sagiboy Troubleshooting and Beginner Help 5 10-20-2009 11:47 PM
Setting the Aperture on a ZX-M/MZ-M APEHAUS Pentax Film SLR Discussion 2 01-14-2008 06:28 PM
All times are GMT -7. The time now is 03:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
