Originally posted by sylvanite Suddenly started today.
It has not been dropped or abused.
Menu will not activate.
Flash will not pop up.
Shutter release will not take a picture when pressed.
In manual mode (M) LCD shows Tv 125 and Av 11 but I am not able to change either of the settings.
In Auto Pic nothing appears in view finder.
The battery shows fully charge. Changed batteries and still shows full charge.
The lens is locked in.
Pushing the Fn button - nothing appears in the screen.
What else can I check to determine if it has to go to a repair shop????
I would get a volt meter to check the output of the batteries. I know with my wife's k100 if the batteries are even a bit down, it starts doing funny things, especially in the winter.
try getting a pencil eraser and rub on the contacts where the batteries touch. sometimes there is a bit of "corrosion" for lack of a better word.
If this doesn't work, if you have the ac cord, plug the camera in and then either update the firmware or re-install the latest.
If that fails, do what I did when my sigma flash wasn't working.... give it a good bang with your hand a couple of times. not sure why it worked, but it worked for me.
good luck
