Originally posted by mikknu
Hello,
Every now and then, I bump into gear that says for Pentax/Samsung. For example my Metz flash.
Admittedly I am mainly interested in lenses. Found some threads here that seems to support compatibility, but doesn't say it outright.
Are camera products from Samsung in general compatible with Pentax?
....If so, could they be worth considering?
Samsung sold versions of the K10D and K20D, called the GS10 and GS20. They are basically identical to the Pentax models, with a few minor differences. For example, the Samsung versions do not produce PEF format RAW files. The do, however, produce DNG files.
It is those two cameras that advertisers are referring to. I don't believe that Samsung currently offers a dslr. The GS10 and GS20 use identical lens mounts as the Pentax. There is no fear of slight incompatibilities, like the infamous "Ricoh Pin".
Samsung dslrs also use the same p-ttl flash system as Pentax.
