06-25-2011, 10:34 PM   #1
navilink's Avatar
Downgrade/Revert firmware of Pentax K-x
I think I have problem with firmware v1.02. Since I upgrade to v1.02, my monitor problem cannot display. But then sometimes can. I've sent it to service centre to fix and replace the monitor, but the problem still arises. So I guess my desperate step is to downgrade to firmware v1.01.
Can any sifu guide me how to do this? I don't want to send to service centre as it's not convenient for me.
06-26-2011, 12:52 AM   #2
See the similar threads below for more details on the actual downgrade.
What's the exact issue you're facing? Chances are that it's not firmware-related.
06-26-2011, 03:42 AM   #3
navilink's Avatar
From what I get I assume I just need to reinstall normally v1.01 over existing v1.02?
The problem happens a day after I upgrade firmware to v1.02. My monitor screen turned off after I used the K-x to snap photos for a while. Then after some rest, it turned on again, but sometimes after a long rest, it still doesn't turned on. It's a random thing I cannot see any patterns. The other thing works just fine, just the monitor can't be turned on no matter what buttons I pressed.
I've actually replaced the whole monitor at service centre, but the problem still there. Of course I would like to return it to service centre, but it's far from my place and very inconvenient.
08-27-2011, 07:38 AM   #4
software problem
i upgrade to my pentax k-x firmware v1.01 with firmware v1.02. Since I upgrade to v1.02, since i upgrade, the camera only shows the Av mode. as i change the modes.
i downgrade it back to with firmware v1.01 but the problem is not solve.
08-27-2011, 08:06 AM   #5
That issue is probably not related to firmware. If your mode dial is broken, you'll have to get it serviced.
08-27-2011, 09:56 AM   #6
reply
the mode dial button was working properly before i upgrade the camera. i don't understand, why the camera not showing and functioning properly after the upgrade with firmware v1.02 of pentax k-x v1.01.
08-27-2011, 10:03 AM   #7
same problem i am facing with my pentax k-x camera after upgrade.
see the link Digital Cameras and Accessories - Official PENTAX Imaging Web Site
if u face again the problem, repeat it.
08-27-2011, 12:18 PM   #8
Maybe try resetting your camera? Might be some sort of conflict!
08-27-2011, 09:21 PM   #9
i reset the camera and i upgrade it again then downgrade it again. now the problem is , when i use the lens aperture on setting 'A', the camera shows all mode and work properly, but i use the lens aperture on menual setting, the camera only shows Av mode.
centre, firmware, monitor, pentax help, service, v1.02
Does anyone know if it's possible to downgrade Firmware from 1.03 to 1.01? Christine Tham Pentax K-5 & K-5 II 73 03-15-2011 02:00 PM
Downgrade Firmware dijkx Pentax K-5 & K-5 II 17 01-16-2011 02:10 PM
???? Firmware Downgrade on K10D 5shot Pentax DSLR Discussion 0 01-07-2011 10:20 PM
pentax k-5 firmware downgrade i83N Pentax K-5 & K-5 II 5 11-21-2010 04:00 AM
K7 firmware downgrade ivoire Pentax DSLR Discussion 42 02-05-2010 02:12 PM
All times are GMT -7. The time now is 09:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
