06-26-2011, 06:53 PM   #1
K-x Sensor Cleaning on Startup
So I find myself flipping the switch quite often to turn my K-x off while not using it, and quickly on again when I need it. With the Sensor Cleaning function on, this means its shaking the sensor quite often. So my questions are:
1. Is this potentially bad for the life of the camera? The sensor, cleaning mechanism, or otherwise.
2. Do you find yourself cycling the power of your cameras often? Or do you just let the camera go into its sleep mode?
Thanks!
06-26-2011, 07:23 PM   #2
Often wondered this myself. I always turn the camera off between periods of shooting....this also begs the question of whether this bad for the battery (ie. is startup using more power than standby)
06-26-2011, 07:27 PM   #3
QuoteOriginally posted by Intric8 Quote
This was also one of my concerns.
06-26-2011, 07:36 PM   #4
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I have found that on my K-x, using the sensor shake, eats my batteries. I turned off the function in camera because of this. I do not turn my camera on and off frequently. And I have it set to go into sleep mode while I'm out shooting so as to conserve battery life too, and a touch of the shutter button brings it out of sleep mode.
06-26-2011, 08:00 PM   #5
tux
I only shake the sensor after I change the lens. I always shake about 3 times in a row after a lens change.
06-26-2011, 10:24 PM   #6
Marc Sabatella's Avatar
Why turn off the camera? It goes to sleep all by itself. And unlike a P&S, it really doesn't use up much battery even when fully on, unless of course you're using it like a P&S and leaving live view on all the time.
camera, k-x, pentax help, sensor
K 5 - Sensor shake on startup Naim Khan Pentax DSLR Discussion 13 10-25-2010 11:59 PM
Sensor cleaning. Modus Operandi Troubleshooting and Beginner Help 17 03-12-2010 04:48 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
All times are GMT -7. The time now is 12:36 PM. | See also: NikonForums.com, part of our network of photo forums!
