Originally posted by aslewis02 I tried pushing the +/- Av button at the top, but will try again.. Maybe I didn't do it right.. I think it has an aperture ring.. I will double check that when I get home.. Would have been helpful if I had brought my camera to work with me.. Just completely frustrated.. Will post again this afternoon
Is this an "A" type lens? If it is, set the aperture ring to the A position. This usually involves pressing a small button as you turn the aperture ring to get it into the A position. If not, you'll have to set the aperture manually with the aperture ring and you can only use the lens in M mode. Make sure you have set the custom menu allow aperture ring to Permitted in this case (set it there anyway to avoid future confusion when you play with some other lenses).
