07-22-2011, 07:07 AM   #46
Use a short rubber tube to remove the retaining ring to - you can probably find one close enough to the correct diameter is the selection of rubber coupling tubes in the plumbing section of your local hardware store.
Or make a rubber washer to fit over the retaining ring, put it over the ring, then with an appropriately sized tube (drinking glass, etc), press down and turn ccw.
07-22-2011, 10:11 AM   #47
RXrenesis8's Avatar
QuoteOriginally posted by pentaxus Quote
Micro-tools.com sells rubber stoppers as "lens ring tools" for somewhere around five bucks.
If you're refering to This I already got a set, and they are too small to remove the ring digitalis is talking about (the cap that sits on the front of the knurled focusing ring).
I am going down to Honolulu for about a month, maybe there is a camera repair shop down there...
focus, infinity, lens, pentax help
What does focus to infinity mean? justtakingpics Troubleshooting and Beginner Help 6 04-04-2011 01:04 PM
K7 and infinity focus (AF) with the DA*300/4 jpzk Pentax DSLR Discussion 22 04-29-2010 09:55 AM
Focus at infinity veebs2 Troubleshooting and Beginner Help 16 03-06-2010 01:47 AM
Infinity Focus DblArrow Pentax SLR Lens Discussion 2 01-24-2010 01:03 AM
Infinity focus problem- M 50mm f/1.7 virgilr Pentax SLR Lens Discussion 3 01-30-2009 08:21 AM
All times are GMT -7. The time now is 09:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
