07-07-2011, 03:14 AM   #1
I made a mistake! How to clean my sensor??
OK, so I bought a blower for my camera. A cheap non rocket brand one. BIG mistake. After attacking my camera with it I discovered it has made things worse. It actually emits dust/residue!! How can I fix this? what sensor cleaning method do you recommend?
I can see a decent amount of must on the mirror but none on the sensor. However have read that the mirror dust is not likely to appear on the images therefore it must be on the sensor?? I'm not sure about a brush as it may be more than just light dust. ie. it has been blasted on by the blower
Thanks
07-07-2011, 05:17 AM   #2
QuoteOriginally posted by camo Quote
Thanks
Step 1 is a good blower. The Rocket blower is dependable.
Step 2 is the Pentax Lollipop (or similar). It's sticky rubber that you GENTLY dab your sensor then a release paper, sensor, release paper, again, again, until you've dabbed the entire sensor.
Step 3 is a wet swab with proper tools.
(Don't try to save .02 cents on any of the above products. After all, it is the heart of your camera you're trying to clean)
Step 4 (if it is really bad) is professional cleaning.
AND, make sure that you've turned on the dust removal on start up function in your camera's menu.
07-07-2011, 06:56 AM   #3
My first resort is the blower - usually only partially successful.
My second resort is the "Arctic Butterfly" brush by "Visible Dust" - usually 100% successful.
My third and final resort (only used once in 12 months) - is the Visible Dust cleaning formula with a Visible Dust swab.
Other people will have their methods including a squirt of dry gas, but mine works for me 100% and I insist on a clean sensor so that I am religious about it.
07-07-2011, 09:14 AM   #4
https://www.pentaxforums.com/forums/pentax-dslr-camera-articles/121739-those-...ml#post1259109
My methods are described in here.
07-07-2011, 10:44 PM   #5
THanks a lot. I shall check out these methods. Has anyone used SENSORKLEAR made by lenspen. It seems it has good reviews
EDIT - Has anyone used the DUST-AID wet and dry kit?
07-10-2011, 09:15 PM   #6
twitch's Avatar
Yes I have, it is excellent if what you want to achieve is to cover your sensor with carbon dust.
07-10-2011, 09:21 PM   #7
QuoteOriginally posted by twitch Quote
I learnt that the hard way as well... But at least it was nice enough to deposit it entirely in one corner for me...
07-10-2011, 09:42 PM   #8
twitch's Avatar
QuoteOriginally posted by adr1an Quote
You got ripped off, I must have got the "premium" version
07-11-2011, 01:30 AM   #9
Never had a problem with lenspen here, used fairly regularly as I change lenses all the time and with m4/3 the sensor is right in the lens mount and permanently exposed. Only niggle I have with it is tha tthe triangular corners tend to get caught in something in the corners of the sensor mount, I'm faily sure I'll break a chunk off in there one day but Ican categorically say my sensor is perfectly spot free without having to resort to anything other than the pen.
blower, camera, dust, mirror, mistake, pentax help, sensor
How to clean my sensor (K-5, K-7, etc.)? Todd Adamson Pentax DSLR Discussion 15 03-17-2013 08:54 AM
New K-X #2 Arrived with Clean Sensor Screen! Blue Jay Pentax DSLR Discussion 2 05-08-2010 10:28 AM
In a bit of a Jam, I need to clean my lenses and sensor but... Kornbread Pentax DSLR Discussion 19 10-14-2009 01:31 PM
Pentax 35mm ltd..I think I've made a mistake larryinlc Pentax SLR Lens Discussion 12 05-07-2009 03:20 AM
istDS vs isD: how big a mistake have I made? WMBP Pentax DSLR Discussion 12 09-01-2007 09:26 AM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
