That Sunpak 544 is a big handle mount flash. I have a similar model and although they're bulky they are also powerful and well built. With 6 AAs instead of 4 the recharge rate is fairly fast. Mine was used by a pro and came with all sorts of accessories (wall charger, AC power cord, remote sensor, sensor extension cord, multiple battery trays, filters, etc).
The 422d is similar to my 433d and is should work in manual and auto thyristor mode even if it doesn't come with a Pentax module.
Both of those Sunpak models have heads that tilt and swivel, which is a nice feature.
The Vivitar 285 is also a nice flash, but the head doesn't swivel. It is more flexible if you can find one that has the remote sensor cord. Older non-HV models may have a high voltage sync, so test them with a DC voltage meter.
This site lists trigger voltages (you're looking for a flash under 24V unless you are going to modify the flash or use it with a safe sync):
Photo Strobe Trigger Voltages
