07-12-2011, 01:45 PM   #1
[langtitle=de]Einstellung Pentax K 10D[/langtitle]
Hab mir eine Pentax K 10D gekauft und wüsste gern welche Grundeinstellung ihr an eurer 10D eingestellt habt,Schärfe,Farbe
Gruss Herby
07-13-2011, 08:42 PM   #2
Stratman's Avatar
I leave mine at a neutral setting. Shoot RAW and adjust in your favorite photo editing software. If you shoot JPEG, maybe turn the sharpness up one notch in the menu.
07-13-2011, 10:46 PM   #3
Thank you
07-15-2011, 07:02 AM   #4
I use my K10D in JPEG mode most of the time. I only use Raw or RAW + if I know there will be mixed light sources or other color temperature problems beyond what the Auto setting can handle.
I keep my Image Tone set on bright, and the Saturation, Sharpness, and Contrast all set on +1. I'm happy with the results I get.
07-15-2011, 01:30 PM   #5
QuoteOriginally posted by chickenherby Quote
Gruss Herby
QuoteOriginally posted by Stratman Quote
Yes! I too use all the neutral settings and shoot RAW (DNG) + JPEG and post 99.9% of everything I have on the internet using the Jpeg. If I plan to print the image, I will work the Raw file for this purpose.
I have found Auto White Balance will work 100% of the time outdoors and may work indoors if there is enough natural light filtering into the area. Otherwise, best to use Tungsten Light White Balance and if this still does not get you good results, working the Raw file usually does. When shooting with ISO's 100 - 400, I will underexpose the image (-1/3), this saves most of the highlights. When shooting from ISO 400 and above, I will try to overexpose (+1/3), this for me, reduces noise etc. I've shot as high as ISO 1250 with good results...
Great camera and sensor, images properly exposed and shot at ISO 100 are pristine... have a good time!
07-15-2011, 10:11 PM   #6
Thanks a lot for all your comments,yesterday the camera comes and now i want to go outside and make pictures.thanks for help ,i will find out now whats the best for me.regards Herby.
camera, pentax, pentax help, photography
ciao a tutti,felice della mia prima Pentax dani 970 Welcomes and Introductions 13 01-15-2017 03:07 PM
Fotos de la K7 negras al editar con PENTAX Digital Camera U yuqui Troubleshooting and Beginner Help 10 02-15-2011 06:44 PM
Acquisto pentax negli Stati Uniti e garanzia Internazionale Mitch Photographic Technique 3 12-07-2010 03:16 AM
Back focus sur Pentax 50mm f:1.4 SMC FA loule Pentax SLR Lens Discussion 6 10-12-2010 08:57 AM
Split-image focussing screen BJ-61 for Pentax 67II phonoline Pentax Medium Format 4 09-24-2010 10:00 PM
All times are GMT -7. The time now is 06:05 PM. | See also: NikonForums.com, part of our network of photo forums!
