Originally posted by Dudley I have two kit lenses that I've had since the late '90s. one is a SMC FA 28-80 and the other SMC FA 80-320. They work OK and I'll most likely keep them but I want to purchase some high quality pieces. What do you think might work for me. I don't mind spending up but I won't waste money.
Dudley
what do you need?
If I look at your present lenses, I would imagine you may wish something wider. I would consider extending the focal length range first, perhaps a sigma 10-20 or pentax 12-24 would be a good addition, if you are pleased with the other lenses, this makes th emost sense.
Is there anything you find limiting with the present lenses, beyond the possible focal length that you are missing.
do you want / need more speed, remember faster lenses add a lot of weight.
do you like / want / need better macro? Perhaps a dedicated macro lens?
Think about your present lenses, where and how you use them, perhaps download a program called Exposure plot (its freee) and analyze the shooting apertures shutter speeds and focal lengths you use presently. If you never shoot wide open now, and are below 1/focal length in shutter speed, faster glass is not necessairly an answer.
you need to plan your kit out, and now is a good time.
For me, things to consider are:
your present lenses represent a focal length range that was typical for film, but 28mm is a little long (IMO) for digital ASP-C format. The biggest question you face is, do you add an ultra wide like a 10-20, or if you don't feel you need to go that wide, do you scale your lenses more to the digital format by getting a 16-50 and a 60-200, and forego the 300mm focal length?
My own kit, coming from film, has a 28-75 F2.8, a 70-200F2.8 and I added a 10-20 ultra wide for digital. I can add TCs onto the 70-200 to get 300 0r 400mm when needed, but I can get away with these 3 quality zooms for a lot of shooting.
If you are comfortable with zooms, there is no need for primes, but again that is a personal choice.
