07-13-2011, 05:26 PM   #1
Pentax 645N: metering with manual lenses
Hello,
I am making the switch from Nikon DX to medium format with the Pentax 645N.
I wonder if the metering will still work if I mount a lens without the CPU contacts?
I know that for low end Nikon DSLRs, mounting a non CPU lenses (without electrical contacts) disables the exposure meters.
Thanks.
Avi
07-13-2011, 07:26 PM   #2
Aristophanes's Avatar
With MF film I use an incident meter. It is far more accurate for the latitude of film than in-camera metering.
I think the metering will still work as the aperture is manually controlled, right? I'm not the guy to answer that, however, as my MF is Mamiya.
Or are you moving to the 645D?
07-14-2011, 04:39 AM   #3
aristophanes...thanks.
I am moving to the 645N.
I want to candid portraiture and that is a reason why metering is important for me.
In the Nikon DSLRs, when when you mount lenses whose aperture you can manually adjust, unless you have electrical contacts, the camera will not meter.....stupid really.
How is the Mamiya? Do you have the above problem with that?
07-14-2011, 10:33 AM   #4
QuoteOriginally posted by psychoanalyst Quote
MF candid portraits. Hmmmm....tricky if the subject is moving. I've used a Pentax 645N and it's AF was none too fast. I'd dial in my zone focusing as well.
My Mamiya gear is manual focus and meters with the lens at the f/stop chosen.
Ask in the 645 forum and refer to this:
Pentax 645N
And:
Jonathan Canlas Photography
645n, camera, contacts, cpu, lenses, nikon, pentax, pentax help, photography
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
accuracy of K-x metering manual / M42 lenses? kuuan Pentax DSLR Discussion 7 01-22-2010 01:01 PM
K-7 LV metering with manual lenses Jadran Pentax DSLR Discussion 6 01-12-2010 12:57 PM
Metering with Manual lenses.. arbib Pentax SLR Lens Discussion 21 01-03-2010 10:22 PM
K10D, manual lenses, and metering vinzer Pentax DSLR Discussion 40 06-30-2007 07:54 AM
All times are GMT -7. The time now is 06:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
