07-14-2011, 07:23 AM   #1
Photos getting deleted after lens swap
I finally got myself Sigma 10-20mm lens couple days ago. To test it i started to take some photos with it. Then I swapped it with kit lens (18-55) and took couple more photos. After I removed SD card and connected to laptop i couldn't find any of my photos - neither taken with Sigma or kit lens, only old photos taken prior to swap.
I repeated steps - took some pics with Sigma and noticed it creates new folder 101-XXXX (there is already folder 100-XXXX with old photos). As soon as i swap lenses folder 101-XXXX gets truncated. WTH? Can anyone explain to me why new folder gets truncated AFTER lens swap?
07-14-2011, 08:56 AM   #2
Does it do this with Other lens swaps? Kit lens vs something other than the sigma? It doesn't make any sense either way. Perhaps try formatting the card and see what happens (save all your other stuff first). I would suggest formatting it with a Full format in the computer rather than an in camera format.
07-14-2011, 09:11 AM   #3
fccwpe's Avatar
make sure you turn the camera OFF before switching lenses or you may short the contacts and fry something more than just your pictures.
07-14-2011, 09:20 AM   #4
internal battery/clock
Has your internal clock reset due to the internal battery losing its charge. It can do this if you leave the camera any length of time without its main battery, or with a flat battery. Possibly you take the battery out when you store your camera to prevent damage. This has come up before and IIRC that was the reason. Check the system clock before you take your next lot of pics, if its wrong the files will be stored in an out of sequence folder and may appear to be lost. (It has also happened to me) HTH
07-14-2011, 09:27 AM   #5
QuoteOriginally posted by JeffJS Quote
I haven't tested it with other lenses but i will tonight. If this continues I will format card and try again.
07-14-2011, 09:28 AM   #6
QuoteOriginally posted by fccwpe Quote
It is OFF when swapping lenses. I wouldn't wanna swap lenses with camera on.
07-14-2011, 09:37 AM   #7
QuoteOriginally posted by keithlester Quote
Interesting points. Well, i didn't swap batteries and they have some juice left in them. Also, it creates new folder meaning the date keeps changing, isn't it? So, time shouldn't get reset after the lens swap but i will check on that.
But even with wrong date they have to be stored somewhere and i can't find them - folder 100-XXXX has couple dozen photos and none of them taken during last photo session (with either lens).
Is it possible that i have set RAW format and they are not visible with camera preview or Windows Explorer? But it is hard to believe cause at least they should be listed as files with no preview, right? I can't check it now cause camera is not with me.
07-14-2011, 09:50 AM   #8
SpecialK's Avatar
QuoteOriginally posted by Black_ronin Quote
I think there is a 500 image limit to folders. Changing lens should not affect files on the card. Did you review images on the card after shooting, i.e., were they actually saved?
07-14-2011, 10:57 AM   #9
I think there is also some setting where you specify when to create new folder. I think mine set to 100-DDMM (DD- day, MM - month) or something like that. I need to check this one too.
Yes, images were there BEFORE every swap - i could preview them in camera screen.
I think it has something to do with SD card/ creating new folder every time. I am sure formatting SD card will fix it, i.e. no folder exists. I was just wondering if anyone faced the same problem as i am having and what exactly causing it.
07-14-2011, 01:56 PM   #10
Pauld's Avatar
You would still be able to see them when you review them on the camera itself. Windows Photo Explorer won't show you a thumbnail image but it should still show you that there is a file there be it either a PEF/DNG file.
I used Sigma lenses a lot and have never had this problem so I would say it has to be something internally with the camera and it sounds a lot like the clock battery.
07-19-2011, 07:43 AM   #11
GerryL's Avatar
That's weird.
First time I heard something like this happening.
I'll be interested how this develops.
07-31-2011, 10:34 AM   #12
Maybe of no value but have you tried a different memory card? Doesn't hurt to try.
camera, couple, folder, kit, lens, pentax help, photography, photos, sigma, swap
Please help - I've deleted all my holiday photos ! :O( Adrian William Photographic Technique 10 08-09-2010 04:29 PM
Do marketplace threads get deleted if unsold? Sasquatch Site Suggestions and Help 14 01-04-2010 01:48 PM
Advice sought on 14mm lens swap selar Pentax SLR Lens Discussion 10 04-16-2009 04:23 PM
Slightly OT about lens swap or sale of Viv Ser.1 solar1 Pentax SLR Lens Discussion 4 12-19-2007 01:26 PM
All times are GMT -7. The time now is 10:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
