07-15-2011, 09:17 AM   #1
K10 can't read SD card
My K10 is telling me there is no SD card inserted when there is. I have checked the card in pc and tv slot and it is ok in those.
Any ideas?
thanks
Chris
07-15-2011, 10:00 AM   #2
Ole
Ole's Avatar
Check your card type and firmware version. The K10D cannot use SDXC cards and there were stability problems with SDHC cards with early firmware.
07-19-2011, 01:54 PM   #3
Try other SD cards.
If there is a problem with your card - bin it (put it in the trash !).
SD cards do fail, if there is a hint of failure, replace it. Lose the card not your pictures.
card, k10, pentax help, sd
Memory Card Error! Pentax K10 D kriss15 Pentax DSLR Discussion 22 07-21-2011 07:39 AM
Memory Card issue with K10 VTPentax Pentax DSLR Discussion 6 04-05-2010 05:22 AM
My computer won't read my memory card Pål Jensen Pentax Camera and Field Accessories 7 07-29-2009 11:32 AM
SD memory card for K10 Brucie Pentax DSLR Discussion 10 01-08-2008 02:24 PM
Sigma EF 500DG super flash owners and K10, you need to read this slip Pentax DSLR Discussion 3 11-18-2006 08:42 AM
All times are GMT -7. The time now is 08:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
