Originally posted by 2cay2 OK, I've done some shots that hopefully will help. I fixed the shutter speed to 1/100 for all shots except the auto shot which did it to 1/100 itself. Then the rest are manual, I've just changed the aperture for each one. Will this be enough info for you?
1. Auto - F11
2. F5.6
3. F4
4. F8
5. F7.1
The last couple are the most realistic to life. It was a cloudy but bright day (mid summer here). Auto was way to dark as usual
I haven't cropped them, just resized for posting here.
Last one looks very good.
Anyways, try getting some white balance cards(or caps there cheap), and that will help balance things out.
Other than that, I'd recommend taking control of your settings(manually) so as to get all you can out of your scenes.
I've always found outdoor lighting to be rather tricky, and I think the reason for this is where the average daylight conditions typically run at the threshold of overexposure. And by this I mean near overexposure in color and luminance and thus the difficulties that follow. One good way to see this is to set yourself up in a vehicle or in the shade and do some real time comparisons using a notebook or external screen between the shots taken and reality. At which point you may notice how truly difficult it is to capture and reproduce TTL light values in a sunlight scene.
Having said that, I don't think it's impossible to emulate bright sunlight scenes in screen or paper.
Then again... there's just no way a print is going to match the brightness values of an sunlit outdoor scenery either.
Anyways, I didn't mean to sidetrack your post, and so I guess I'll just leave it at taking control of your settings(manually) is likely the best method at gaining control of your scenes in cases such as these. And of course, WB caps and cards can help, but with the latest crop of software out there these days make those less likely to be necessary.
