Originally posted by Elva I have had similar problems where the dust detect failed to pick up the dust and a blower did the trick. I used the sky as a test. As there was nothing for the autofocus to focus on I set the lens to infinity and took a photo of the sky. Cleaned the sensor and did a re check, used my PC to do the check for the dust speck.
I second that. The "sky test" works best because it is a practical image showing the real time result. I usually set my aperture to f13, manual focus to past infinity,set the lens to 50mm and shoot away. Once you have the photo downloaded, it helps to boost the contrast way up to really see the dust (I use Picasa and slide the "shadows" bar all the way up). Just remember, the photo you are looking at is flipped, so if the dust shows on the right upper corner, it's really in the lower left.
