Originally posted by EdF Now I see that the lens is a bit fogy, do you reckon that will degrade the image a bunch?
Foggy? Now you have a soft romantic portrait lens! People pay good money for those (when the softness is intentional).
Yeah, severe fogging can degrade IQ. If the fogging is due to condensation of humidity in the lens, like when taking the lens form AC indoors to tropical outdoors, try setting a hair drier on LOW and blow it on the glass. From then on, don't subject the lens to sudden heat/humidity changes.
If it's hazing due to deterioration of the lens-element cement, or many many TINY BUBBLES (la la la!) in the glass due to element separation, the only somewhat reasonable cure is to replace the element(s), like by finding the same lens with a munged body and doing a glass transplant. (The unreasonable fix involves re-grinding the element surfaces at maybe US$100+ per surface. Right.)
The lens may still be usable if you don't point it into bright light. Or just save it for soft hazy romantic portraits that disguise skin diseases. You can charge extra!
