I'm bit of a neebie to DSLR's but guess I've had my K-m for about 18 months. Now I think the stock lens has developed a fault so I'm looking at getting a Tamron 17-50mm as a replacement. The question is, should I opt for the older one (Tamron 17-50mm f/2.8 XR Di II Lens) or the new which I believe is almost the same lens but with VC built in. As the Pentax K-m has shake reduction feature built into the housing will I actually benefit from VC or would I be wasting my cash?
Any advice appreciated!
Oh, and hello all - this is my first post!
