07-25-2011, 08:26 PM   #1
Camera lock out when too hot
The other day I was shooting in LiveView. The camera had been in the car all day (hidden - not in the sun) and the air temperature when I started shooting was 35C. After a few minutes the temp warning thermometer appeared.
The K-x manual states in part: '...If Live View is used in places where the camera may become hot, such as in direct sunlight, l (temperature warning) may appear on the monitor. Cancel Live View, as the internal temperature of the camera is rising....'
I could not cancel LV, nor could I even turn the camera off! When I rotated the on/off switch to off, the camera did not turn off and the light next to the switch stayed on. I had to open the battery door to turn the camera off.
Bearing in mind what the manual states, does there appear to be a problem with the camera?
07-25-2011, 10:01 PM   #2
hcc
hcc's Avatar
LiveView requires a lot of power to supply the electronics and the risk of overheating in LV is real. This has been reported several times in PF during hot weather.
Simply try to avoid to use LV during a heat wave.
07-26-2011, 08:54 AM   #3
QuoteOriginally posted by kitkat Quote
If the ambient temperature outside the car was 35C, it was likely much, much hotter inside. If you didn't let the camera cool down before shooting, it was most likely well over the 40C the K-x is rated for.
Sounds like the camera overheated and locked up. If you've only done this once, it's unlikely there is any permanent damage.
camera, day, pentax help, switch, temperature, view
off camera hot shoe question keithbaran Photographic Technique 7 02-11-2011 07:34 PM
Photozone Reviews Tamron 70-200 2.8 HOT! HOT! HOT! JHD Pentax SLR Lens Discussion 31 02-03-2011 09:11 AM
Will the metz 48 af1 mounted to camera hot shoe trigger af360 wirelessly? boosted03gti Flashes, Lighting, and Studio 11 10-26-2010 02:36 PM
Recommendations For a Pentax K Mount Camera w/ AE Lock momus2 Pentax Film SLR Discussion 24 10-19-2010 04:56 PM
hot pixels on a brand new camera? OniFactor Pentax DSLR Discussion 17 12-03-2007 04:51 PM
All times are GMT -7. The time now is 01:30 PM. | See also: NikonForums.com, part of our network of photo forums!
