07-27-2011, 05:51 PM   #1
Blurr the background
I tried to use AV mode and set the f value at the lowest when trying to zoom. I set the iso settings auto. I am not able to blurr the background. Any tips will be very useful. I use sigma 18-200mm and K-R Boday
07-27-2011, 06:01 PM   #2
zoom in, get closer
07-27-2011, 06:11 PM   #3
suncrimson's Avatar
Zoom in and step back
OR
Get closer and zoom out
(since you may need to keep the composition) : )
Long focal length will reduce the DOV effectively.
You can try to move your object far from background a little be if you can. That helps too.
If changing lens is possible, get a prime lens with large aperture, a lens like 50/1.7 will solve your problem well.
07-27-2011, 06:37 PM   #4
aleonx3's Avatar
QuoteOriginally posted by rr4562 Quote
When you say "set the f value at the lowest" do you mean smallest or biggest aperture? What focal length did you use for the shot? The OOF (out-of-focus) effect depends on the DOF which also depends on focal length, aperture and distance to the focus subject.
07-27-2011, 07:09 PM - 1 Like   #5
psychdoc's Avatar
Sigma 18-200 is not the best for getting out of focus background. And the out of focus areas are kinda harsh. Get a lens like the DA 70mm f2.4 or 50mm f1.4 etc and this is much easier to do:
However get close to the object, zoom in close and make sure whatever is in the background behind the object is far away.
This was taken with the sigma lens that you have at 63mm at f5.6 with a k2000 body. The body does not matter that much.
07-27-2011, 08:05 PM   #6
aleonx3's Avatar
As other posters suggested, get closer and open up the aperture (e.g. F2.5 in the picture below). This may not be the best bokeh, but you get the idea from a wide-angle lens 24mm about 10 inches from the bug.
07-27-2011, 09:16 PM   #7
RioRico's Avatar
You get blurred backgrounds by exploiting subject-to-camera distance, and DOF (depth of field). Separating the subject from the background is called subject isolation. The closer your are to the subject and the further away the background is, the more the background blurs.
You control DOF by selecting focal length and aperture. Your goal is thin DOF, so your subject is sharp and everything else isn't. Longer focal lengths (like 100mm) have thinner DOF than do shorter focal lengths (like 28mm). Wider apertures (like f/4) have thinner DOF than do tighter apertures (like f/11). So a 100mm lens at f/4 has better subject isolation than a 28mm lens at f/11.
As a photographer, your trick is to find the right mix of distances and focal lengths and apertures that produce the blurring you want. How to get there? Study, and practice practice practice. Have fun!
07-27-2011, 11:05 PM   #8
There is a very useful website that covers depth of field:
Hyperfocal Distance and Depth of Field Calculator - DOFMaster
07-28-2011, 01:07 PM   #9
Thanks for all the suggestions. I will give it a shot. i used the f value at 3.5 using my 18-200mm sigma lense and choose automatic iso and AV mode.
07-28-2011, 01:49 PM   #10
Ira
As long as you're in Av mode, it's okay to use auto ISO, although I don't recommend it. With this configuration, the camera will choose shutter speed and ISO--not affecting your aperture/DOF at all.
So as said above, narrow DOF with the way you set the camera has to do with your camera-to-subject distance. SO....
Start shooting manual in these situations. You DO want to select the optimum ISO and shutter speed depending on what you're shooting, and getting the right shot is a balancing act amongst the 3 elements (F stop, ISO, shutter speed).
In any given situation, you want to use the lowest ISO possible. If you use auto ISO and it gives you ISO 400, and a shutter speed of 1/500, you're much better off selecting ISO 100 at 1/125th, if that's enough to freeze the subject movement.
I am NOT a fan of auto ISO.
07-28-2011, 01:57 PM   #11
Ash
Community Manager
Ash's Avatar
As you venture further into photography and develop interests in thin depth of field, you may find yourself reaching the limits of your existing gear (specifically the lens). It's then when you realise you need a more capable lens for the job, such as a wider maximum aperture lens, and will need to invest in the appropriate one for your needs.
Nevertheless, the advice given so far will maximise your ability with your current gear to blur out the background - subject close, aperture wide.
07-28-2011, 07:11 PM   #12
Switch to manual focus and set the focus as close as possible, move closer till focus is achieved. Explore the extreme, get over it and find a balance you can apply to what you want to shoot.
As a bit of a curiosity question, what sort of results are you getting and how much blurrier would you like it to get?
08-03-2011, 04:50 PM   #13
GerryL's Avatar
It's easy with the Sigma 28-200mm.
As Rio Rico said, just zoom-in and open the aperture wide.
Here's one taken with the Sigma..although I forgot at what focal length I was in and at what opening.
08-03-2011, 07:45 PM   #14
Blur the background of what?
...and how much blur do you want?
For maximum 'blur' get as close as you can to your subject and still be in focus. Open the lens to the maximum aperture. Nothing wrong with auto ISO in Av mode, Focus, Shoot. Done. That's the most 'blur' you're going to get with your lens(es). Want more Blur? Get a faster lens, a macro lens, close up filters, extension tubes, bellows, etc.
08-03-2011, 11:02 PM   #15
QuoteOriginally posted by GerryL Quote
It often needs a bit more thought than simply making Dof as shallow as possible. Will also the subject be in focus? Where should the sharpest point be? What will be out of focus (especially in the foreground) that will be distracting? Is the background far enough away to get a nice smooth bokeh rather than blurry clutter?
See Hyperfocal Distance and Depth of Field Calculator - DOFMaster
background, blurr, camera, pentax help, photography
Machinery '66 Mustang - Brenizer Attempt #2 - No blurr this time :) adr1an Photo Critique 2 07-08-2011 10:44 PM
Too bright background RonakG Troubleshooting and Beginner Help 11 02-21-2011 09:41 AM
Musty muslin background e035830 Photographic Technique 6 12-04-2010 07:42 PM
Blurring background with Photoshop Elements 5 WalterGA Digital Processing, Software, and Printing 3 08-08-2009 08:46 PM
Do you accept your picture is slightly blurr? raider Photographic Technique 19 01-18-2008 03:42 PM
All times are GMT -7. The time now is 05:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
