Originally posted by asp1880 There's also a wireless flash underexposure bug actually. Close and midrange focus gives correct wireless exposure, distant focus ( > ~2m) gives 3-4 stop underexposure. Easy to verify using manual focus. Focus close, it's OK, focus the same scene distant, it's underexposed. I see it with K-5 and the AF540 flash. It's also reported on the other forum.
Sincerely,
--Anders.
Is it a bug or is it a design limitation?
As i understand it, pttl increases or decreases the power of the flash dependent on what light the sensor is experiencing. I could be wrong, but i don't think pttl knows what distance the remote wireless flash is from the camera. But flash power increases/decreases are not linear with regard to the distance of said flash from the camera, square root reduction i believe. If the camera cannot compute the distance to the remote flash, then a reduction of power that would have worked on a close wireless flash, will result in excessive underexposure in a more distant flash.
I remember in my K20 or K10 manual, there was a warning in there that wireless flashes should be within 10' of the body, but i can't check it since i'm on the road. So i'm wondering if this isn't a design limitation of wireless flash usage in general.
I do know that a Metz flash on my camera body in direct orientation, can compute the distance from the flash to the subject. But in any other flash orientation than direct, or in off-camera, that data area is left blank on the flash LCD.
Off topic - i was watching a training video on using fill flash recently, and the well-known pro, Nikon equipment, was going around adjusting the remote flashes manually rather than using his radio trigger controls.
For the remote flash work i've done recently, up to 35 feet away and out of view behind concrete walls, I've used manual adjustments and got there within 1 or 2 iterations.
