Originally posted by Ash I wouldn't have suggested new batteries if you mentioned it earlier.
Nevertheless, it sounds as if your camera is causing some sort of short circuiting to effectively drain a new set of batteries in 15sec. Can you confirm this by investigating your battery contacts and compartment?
Thanks, I actually suspected that it might be a circuit somewhere. Yes, I
checked the battery compartment - looks like new, no slightest damage (I take good care of it - it's my secondary camera body and it didn't see much of use at all...). Could it be somewhere else? Though, having said that - where in a hell it can possibly be? Camera has never been opened, has never been even slightly wet, never been dropped, etc... The only thing that come to my mind is that once upon a time (I was in a hurry) I tried to plug a remote into power supply plug (which is next to remote)... Again, there is no visible damage... Is it worth to open camera and have a look at it? I was hesitating in doing it - I am not that good with precise devices...
