Originally posted by Xarcell Unfortunately I know nothing about aperture, but I guess now would be a good time to learn?
Indeed. Here are the basics:
Inside the glass of a lens (usually) is some mechanism for controlling the amount of light passing through. This is the aperture. The most common mechanism is a set of iris blades that open and close. Aperture is measured in f-stops. The aperture is the ratio of iris opening diameter to lens focal length. If the lens is 50mm and the iris opening is 25mm then the aperture is 25/50 = f/2. This f-stop measurement means you can calculate exposures (and other stuff) without having to know exactly what the iris opening is.
OK, that was the tough tech part. The implications of aperture are: The smaller the iris opening, the less light gets through -- and up to a point, the sharper the image is! And the converse: The larger the opening, the more light passes, and the softer the image. A wider (larger) aperture lets you shoot faster action and in dimmer light.
Before anyone jumps on me, I'll admit to using 'sharper' and 'softer' loosely and inaccurately here. What actually happens is a change to the depth-of-field or DOF. DOF is complex, but it boils down to the range of distances of acceptable image sharpness. A tighter aperture (larger f-stop number, like f/16) produces thicker DOF, so the image might be sharp from 2m to infinity. A wider aperture (smaller f-stop number, like f/2) produces thinner DOF, so the image might only be sharp between 2-4m. DOF depends on aperture, and lens-to-subject distance, and many other factors that we needn't worry about right now.
Faster lenses (with wider maximum apertures) usually cost more to produce and buy than slower lenses (with tighter apertures). Of my manual-focus Fifty's (all bought used), my ultrafast SMC-K 50mm f/1.2 (commonly called a K50/1.2) was a good deal at US$250; my good fast SuperTakumar 50/1.4 was a steal at US$50; and a decent but slower M50/2 often WON'T SELL for US$10.
_________________________________________________________________________
So, pros and cons of faster and slower lenses.
FASTER: Costlier; more artistic control of DOF; often softer wide-open (at maximum aperture); able to shoot faster action and in dimmer light.
SLOWER: Cheaper; less DOF control; sharper wide-open; need more light or higher ISO (which introduces noise), or use with lethargic subjects.
All this applies to prime lenses, those with a single focal length like 50mm. With zooms, whose focal lengths can vary (like the 18-55mm kit lens), it's even worse. For our cameras, the number of FAST zooms (faster than f/2.8) ever built can be counted on one hand. Numerous fairly fast (f/2.8) zooms exist. They are not cheap. Long ones are not small. Read the lens database here and prepare for sticker shock. But a used f/3.5 zoom may be MUCH cheaper than a used f/2.8 zoom, even though the aperture difference is only 1/3 f-stop. And zooms with variable maximum apertures, like a 70-200mm f/3.5-4.5 zoom, tend to be of somewhat lower quality than one with a fixed maximum aperture, like f/4.
Uh oh, those numbers again! F-stops are measured as this series: 1, 1.4, 2, 2,8, 4, 5.6, 8, 11, 16, 22. (These are multiples of the square root of 2. Don't worry about it.) Each stop passes half the amount of light as the next number. And this tells us how to adjust shutter speeds. So a lens at f/2 only passes half the light as the same or another lens at f/1.4; and to get the same exposure value, we need to double the time the shutter is open. So if the camera meter says to use f/1.4 at 1/100 second, and we want more DOF, we set the aperture to f/2 and the shutter to 1/50. I hope that's clear!
There's much more, like diffraction. If you use an aperture tighter than f/16, light diffracts around the iris blades and the image is fuzzier. Most lenses are sharpest around f/8, say in the f/5.6 to f/11 range. But if you want thinner DOF or just need to grab more light, you must open-up the aperture more. There are trade-offs, many many trade-offs. Every camera+lens selection, and every picture shot, is a problem to be solved. And that's why we're all nutz. Cheers!
We're all here because we're not all there.
--Anon.
