08-06-2011, 09:04 AM   #1
SlickYamaha's Avatar
What size do you crop in?
So Im doing some Graduation photos for some friends today, and after looking through my site and trying to make up a cheap package they can purchase, Im not sure what size to crop the photos. I usually try to crop everything in 8x10, but if they are going to be buying wallets, as well as maybe 4x6, 5x7, as well as 8x10 and possibly 16x20, none of that will work without losing parts of the image. (obviously) But what would be a "standard" crop size that will relatively accommodate the best for everything? Should I go with what will look best on the larger photos (8x10/16x20) or what will look best on the wallets (which im sure they will be handing out tons of)
Little help?
08-06-2011, 09:04 PM   #2
ramseybuckeye's Avatar
I don't think one size fits all works. Maybe ask them what they want, and let them know if it doesn't work.
08-07-2011, 09:12 AM   #3
QuoteOriginally posted by ramseybuckeye Quote
Yeah, I was just wondering if there was a "standard" size that most people went with. It looks like the camera puts out 4x6 by default, so I guess Ill just stick with those
Just kinda makes it awkward to go bigger (8x12 frames are hard to come by vs 8x10 and having to crop)
08-07-2011, 10:30 AM   #4
Jodokast96's Avatar
I've found that cropping to a 5x7 ratio works pretty well, as long as you leave a little bit of extra room. It's seems to fit right in between most of the common ratios, and is the same ratio as wallet size.
5x7 =
7.1x10 or 8x11.2
4x5.6 or 4.3x6
16x22.4 or 14.3x20
08-07-2011, 10:46 PM   #5
I can tell you with certainty though, that unless you know exactly what your client wants, you're going to have to make adjustments no matter what so might as well stick to whichever works for you.
I used to crop to 4x5/8x10 all the time, but that was just because artistically, I preferred the more square look. I've switched to doing more of whatever works for the photo, going custom (4x10, 5x10, etc) when the photo calls for it.
camera, crop, im, pentax help, photography, photos, size, wallets
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Do you shoot and crop in camera or shoot loose and crop in photoshop? hockmasm Pentax DSLR Discussion 23 05-02-2010 06:10 PM
Night To crop or no to crop...? esman7 Photo Critique 17 01-17-2010 08:28 PM
Does the "crop factor" just crop? jboyde Troubleshooting and Beginner Help 8 01-03-2010 08:18 AM
To crop or not to crop ? fredg Post Your Photos! 2 09-20-2009 02:02 PM
All times are GMT -7. The time now is 01:42 PM. | See also: NikonForums.com, part of our network of photo forums!
