08-06-2011, 11:08 PM   #1
Melanie Crause's Avatar
aperture ring setting
Hi all, please tell me how to set my camera to apperture priority, so it will allow the apperture ring to be set to any other setting as auto.
When I turn the aperture ring, my camera would not respond, it only flashes av-- and inside the viewfinder, I can only see F--
thanks!!
08-06-2011, 11:11 PM   #2
Go into the Custom menu and set the function that says Allow Aperture Ring (or Use Aperture Ring) to Permitted. Then (if this is a K mount lens) go to M mode because that's the only mode that will work with a non A, K mount lens. With the others, it will always shoot Wide open.
Which camera are you using?
For more info..
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/110658-using-ma...x-dslrs-f.html
Welcome aboard.
6800
08-06-2011, 11:19 PM   #3
Thank you so much!!! Will try this!!
08-06-2011, 11:29 PM   #4
Wow!!! so easy if you know what to do!!! I guess we all have to start somewhere!!! Thank you, I apprecheate your help.
08-07-2011, 07:22 AM   #5
You are welcome. Hope to see some photos soon
08-07-2011, 08:48 AM   #6
Marc Sabatella's Avatar
Just to be clear - all of this applies to manual lenses only. Modern lenses are designed to work with the aperture in the "A" position and provide full use of aperture priority.
08-11-2011, 11:23 AM   #7
Thanks Marc, I have manual lenses, and are now happily enlightened!!! (guess we all have to start somewhere!! LOL )
wish I can attend a photography course, but there isn't anyone that gives courses in my town
aperture, apperture, camera, pentax help, photography
Enabling Aperture Ring yustr Pentax DSLR Discussion 17 03-20-2011 06:03 PM
Permit Aperture Ring drjaxon Pentax DSLR Discussion 5 02-03-2009 08:37 PM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
Aperture ring on my *ist DL FastPhotography Pentax SLR Lens Discussion 7 12-25-2007 09:53 AM
K10D and aperature ring setting WildSioux Pentax DSLR Discussion 2 03-20-2007 09:49 PM
All times are GMT -7. The time now is 02:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
