Originally posted by cats_five I used to use RAW+ because Pentax hadn't released a code I could use with Windows 7 x64 to browse the photos in Windows Explorer. Now, for the K7 and most other Pentax DSLRs, Microsoft have. However I've set the camera to only take small JPGs, so I've left the setting as is. I do use the JPGs from time to time, for Ebay and emailing.
Same for me, but instead I started using Adobe Bridge instead of windows explorer. I used to keep both when I was doing a lot of startrails stuff because startrails.exe only accepts JPGs. But I wanted the RAWs in case I needed to mass adjust.
I've never even used the RAW button on the K-7. I feel very sorry for penties_rider if you've been pressing your RAW button all the time. The manual says
Quote: RAW+ / Images are saved in both RAW and JPEG formats. When the RAW button is pressed, images are temporarily captured in both formats. (p. 189).
What it should have said is perhaps just
and prevent this poor fella's obvious confusion that the default format choice RAW+ also requires you to press the RAW button. After all there's a seperate spiel about the RAW button on page 189 so maybe they should have explained all of how it works there rather than structuring the way they did.
Anyhow. File format RAW+ is definitely what you're looking for.
