I'm guessing the flash is just broken and the camera is probably set to not fire if the flash isn't charged. I don't see this as something worth fixing really, the pop up flash is quite useless and fixing it would probably cost more than the camera is worth. I probably used it a dozen times and hated the results every time. Get a hotshoe flash if you want to use flash, preferably something with a head that tilts and swivels. Usually if the pop up breaks, the hotshoe still works.
If something really is broken and it costs around $100 to fix, you can pick up a Pentax af200fg flash instead and have more power than the pop up, have the ability to use it off camera if you pick up some cheap wireless triggers and it won't be blocked by the lens hood. It doesn't tilt or swivel, but it is a huge step up from the pop up.
I still think you're just misunderstanding the number in the LCD display. It is the number of pictures remaining, not how many you've taken, it is backwards from a film camera.
