Originally posted by SgtSmurf I would like to share my excitement with the Pentax community on my new purchase. I've been seriously considering a new camera for the past month or so. Naturally I ask my seasoned photography friends for advise. No surprise here, they all suggest either Cannon or Nikon. I have nothing against either models but after a good amount of reading I've decided to go with Pentax. So why'd I ask their advice in the first place right?? Anyway...
I read some suggestions from a thread where another person needed help with getting equipment. She got a free lens from Wheatfield!!! woot, lucky her. A bit of good advice I read was to use a free tool to figure out at what range you normally shoot before you go and plop your $$ on a bunch of lenses. So I bought a used 18-55 kit lens for a little under $100. I plan on getting a wide angle eventually. That saves me a little money compared to buying the K-5 with lens but I end up getting the same thing. Woot!
I'm an avid Salsa dancer and plan on taking plenty of pics of people spinning and grooving in the dim lit dance halls (in fact im going dancing after I post this) so I ordered a FA50 f1.4 too. I read this is the most fabulous fast 50 around! I have no idea how to manually focus but I'll figure it out eventually right =)
Well, thats all. Hope I'm on the right trail. Wish me luck
Hi,
Welcome to the Pentax community and congrats with your new K-5.
An excellent choice!
Perhaps you should think and read some more before buying the FA50 f 1.4.
I have that lens (its a very good lens by the way), and while it is f1.4, there are 2 things to consider:
1) Using a lens a f1.4 will give you *very* shallow depth of field (everything that is sharp in front of/behind the focus area). Lots will be blurred.
2) F50 has a small angle to work with. It depends what the distance to the subject is if that will work for you or not.
I don't know if flash is permitted and if you can get close, but with light and camera angles differently composed to the subject, you can get very nice effects.
Also a zoom is more versatile and working with smaller apertures (higher f numbvers) will give you sharper pictures.
Your K-5 is capable of making good picture in very low light conditions, so flash is not necessary in many occasions.
I know a bar is not the same as a dance floor, still have a look at this:
Chris shows in this video bar photography techniques which you might be able to apply to dancing situations as well.
My choice for dancing photography would be: DA*16-50mm f2.8 (or the Sigma/Tamron 17-50mm f.2.8) and a DA* 50-135mm f 2.8. Or some primes (15mm, 50mm, 77mm, 90mm) covering that range.
And a flash for specific action effects.
Have fun with the camera!
Bert
