Originally posted by mikknu I was using a K-x + Tamron 17-50 Di II with a Metz Mecablitz AF48-1. I set the Metz to HSS for high sync, set the shutter to 1/800 and ISO to 800. Tried both in Tv mode and Manual mode. In Tv mode, the aperture size was blinking at 2.8, wanting to go lower.
In Manual mode I had to set ISO at minimum 2000 just to get enough light according to the EV meter.
I don't think that can be right, but maybe I am wrong? The forest wasn't that dark after all. Just always thought that a flash was suppose to eliminate high iso values.
Any suggestions on what I am doing wrong?
Tv mode is trying to meter for ambient, couldn't get anywhere near it, so no surprise it's blinking the aperture value at you.
It's a very interesting comment you make about manual mode needing ISO2000 "just to get enough light according to the meter". Well that is actually very good news if I'm understanding you correctly. First thing to understand is the meter in any mode is indicating ambient exposure, there's no regard for the flash in the meter reading.
In that situation, wanting a bit of reach, I'd try shooting at ISO1000ish and let the flash provide the extra 1 stop of light (which is exactly what pttl will try and do for you). With 1/800 and a Metz 48 don't expect a whole lot of reach, but the flash will tell you exactly what reach it will give so no need to guess. The flash power you lose in on a sliding scale in HSS, just stepping into it loses you 2/3 of your reach, and then every 1/3 stop the reach gets less and less. You need to compensate for with ISO & shutter..... or getting closer
"Just always thought that a flash was suppose to eliminate high iso values." that belief is wrong I'm afraid, especially for using HSS in a forest. I frequently use ISO800 and even ISO1600 for flash photography, those ISOs are nothing to be afraid of in todays DSLRs.
