08-17-2011, 05:42 PM   #1
No Access to C MENU in K-7
When I press MENU button, it displays the page 1: JEPG, 14M, ***, ....., SR (off). I press the "right" button and cannot reach the custom menu. I don't know what's wrong with the software.
08-17-2011, 06:43 PM   #2
hcc
hcc's Avatar
Is the Dial mode on Green mode?
If so, place it to P (Hyperprogram).
If not, tell us more about your settings.
08-17-2011, 07:24 PM   #3
QuoteOriginally posted by hcc Quote
On the K5, the custom menu is not available at all in Green Mode. They REALLY don't want anyone changing whatever settings they've deemed appropriate for that mode.
08-17-2011, 07:26 PM   #4
Thanks for the help. I moved the dial away from Green Mode and it worked. I seldom use this camera. In over a year since I bought this camera, the battery was charged only 3 or 4 times. It still has the version 1 firmware. I use my K-x and the two MZ film cameras much more.
Now I need help to up-date the firmware. The instruction says: use a blank SD card, then it says: insert the formatted SD card to the computer.
How do I format it? Can I use the same SD card already in the camera? I don't have a card reader and no such port on my computer. Then It says:
Insert SD card in camera and connect camera to computer.
Do I need to turn on camera power?
How do I put the up-date file in "root directory"?
08-17-2011, 07:47 PM   #5
hcc
hcc's Avatar
QuoteOriginally posted by violini Quote
Format the card in the camera.
Then It says:
Yes
In a computer HDD, the root directory is C:\. The top one.
08-17-2011, 07:53 PM   #6
In step 1 of readme: Copy fwdc204b.bin to root directory in SD card.
I don't know how to do this.
08-17-2011, 08:23 PM   #7
1. You download the appropriate file to your computer. If it's a PC, it will be an EXE type file. Click it to run and unpack the firmware (I assume you've done this already).
2. Somehow, you manage to get your photos from the card to the computer, Correct? Either with the USB cable connected to the computer and camera or with the card in the computer card reader. Either way, the camera/card becomes an extension drive on your computer (D: E: etc). Simply copy the BIN file to the card so that On the card, you see both the file AND, the DCIM directory (where your photos are recorded in the camera).
3. MAKE SURE YOUR BATTERY IS COMPLETELY CHARGED.
4. Press Menu while turning on the camera (with the card in the camera).
5. Answer Yes to the question you see to update firmware.
6. Your will see Phase 1 Followed by Phase 2 followed by Completed (and the red light next to the card door flashing).
DO NOTHING UNTIL YOU SEE COMPLETED, DO NOT TURN THE CAMERA OFF BEFORE THEN OR YOU WILL HAVE A PRETTY BRICK.
7. Format the card in the camera (setup menu) and you are ready to take photos again.
Good luck.
08-17-2011, 08:25 PM   #8
shooz's Avatar
You will need access to a computer that can handle an SD card, with either a built in slot or a card reader.
Download the software and open it on the computer.
Copy the firmware upgrade to your SD card.
The root directory means the folder the camera created when you formated the card.
You can also format the card in the computer and just copy the file over.
Either way works.
Put card back in you camera and follow the readme instructions to the letter.
That's the most important part.
hope this helps.
08-17-2011, 09:40 PM   #9
Thanks for the help. First I click the up-date file, then "Control C", insert SD card in the computer slot, 2nd window appears with "DCIM" on it, press "Control V". The file is in SD card. On the camera, it shows the battery is still "green", it was charged about 5 months ago. I'd better charge it again before I up-date the firmware.
08-18-2011, 12:21 AM   #10
Just to be safe, Yes.
08-18-2011, 10:16 AM   #11
This is the first time I update the firmware. I'll write down the steps which may be useful for other first time users.
1. Format SD card by going to SETUP MENU #4. It also deletes whatever data in the card.
2. Charge the battery.
3. Download update file (exe) from Pentax web site. Run it and you get 2 files: readme and bin.
4. Print out readme; it's an instruction. My laptop has a SD card slot.
5. Click bin file (it will be highlighted) and press "control C".
6. Insert SD card into computer; a window appears with "DCIM", then press "control V". Now the window has DCIM and the update file. Remove SD card from computer.
7. Install fully charged battery and SD card.
8. Turn camera power ON while pressing MENU button.
9. "NOW LOADING" appears on monitor and will change to "PROGRAM UPDATE'. Use 4-way controller to select "YES" and press "OK". "UPDATING' appears.
10. "COMPLETE" will be displayed at left bottom, then turn off camera.
11. Re-format SD card to delete the file.
08-18-2011, 10:58 AM   #12
Looks like you are now an expert at it. Now get out there and enjoy the camera. These aren't meant to sit in bags unused
button, menu, pentax help, press
Question Marketplace Access soppy Site Suggestions and Help 3 12-14-2010 12:23 PM
Debug menu access for the K100DS? Nachodog Pentax DSLR Discussion 3 04-14-2010 02:27 PM
For Sale - Sold: Tamron 75-250mm, Access 35-70mm f/2.5-3.5, Access 70-210mm f3.5, Kenlock 80-20 hinman Sold Items 14 03-20-2010 12:25 PM
Access Control list Kenn100D Non-Pentax Cameras: Canon, Nikon, etc. 6 12-17-2009 12:08 PM
All times are GMT -7. The time now is 03:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
