Originally posted by RKKS08 To Lowell Goudge:
There seem to be controversal opinions about that subject.
See
Testberichte - Meine Homepage http://s215846244.online.de/wsb4627126001/Testberichte/Test%20135mm.pdf
It is unfortunately in German only, but there is a sheet at the end of the PDF which should be self explaining.
In short, they say the takumar bayonet 135/2.5 is indeed the worst, but the takumar bayonet 135/2.8 is way better, and in overall performance better than or equal to the K 135/2.5.
They also think Pentax must have improved the coating of the takumar bayonet during the production cycle without giving notice, as they found the flare resistance of the Tak 2.8 against the 2.5 WAY BETTER.
Please don't put the blame on me if you think this test is rubbish, I was not involved.
To be honest, I had not seen or heard of a K mount Takumar 135F2.8 before, only the 2.5, so I can't comment one way or the other on the difference optically between the Tak (bayonet) 135/2.8 and the K15/2.5, other than to point out that any 4 element design will be very bad relitive to more complex 6 element deisgns with respect to the management of CA.
I would have to see the two perfrom side by side, but the rest of the conclusion is what I said, the tak (bayonet) 135/2.5 is the worst 135 pentax made.
I also can't argue that coatings improve over time, and the later tak 135/2.8 should, even if it is not SMC be better than the tak (bayonet) 135/2.5 simply due to this fact.
