08-20-2011, 11:38 PM   #1
Pentax K100D Super rhymically vibrating every second on long exposures...
I've had my pentax k100D super since 2008, bought it brand new. Today I was trying to do some long exposures and the camera was rhymically ticking/vibrating about every second. I changed the lenses, turned it on and off, switched from manual to auto focus, turned shake reduction on and off... nothing. I actually ended up accidently banging it AFTER it was doing this and it got slightly better. As far as I know the camera hasn't been dropped, theres no damage to it besides very small cosmetic things.
I am TOTALLY baffled. It doesn't do it at all during short exposures. I probably wont fix it since its such an old camera and its still a good extra extra backup to have at a wedding since I wouldnt be doing long exposures at one anyways
08-21-2011, 05:52 AM   #2
blackcloudbrew's Avatar
Is this the same noise that occurs when you clean the sensor?
08-21-2011, 06:55 AM   #3
IIRC my K100D did the same thing when SR was on. Try turning the SR switch off and see if it makes a difference.
08-21-2011, 11:19 AM   #4
I turned the SR on and off MANY times... and no its not the same noise... its more like a clicking. I've never had to clean the sensor (like open it up and actually clean it) not at least on this camera but I don't remember that noise being similar to this...
08-22-2011, 05:55 AM   #5
Perhaps there is a language barrier here - I didn't ask you to turn SR on and off, I said turn it off to see if the noise persists. (ie. turn SR off, take a long exposure, listen for the noise.)
If you've done this and the problem persists, then you can be confident it's not related to the SR system. Try taking a long exposure without a lens (a remote shutter release will help here), and look inside the body to see if there's anything moving inside the camera.
Finally, how are the images? If there is no loss in image quality, and no defects, I wouldn't worry about it.
08-25-2011, 03:29 AM   #6
Oh yes I did try taking it with the SR on and off. But I'll try it without a lens to see if something is stuck inside or lose.
The images obviously don't come out when on long exposure, they come out with camera shake because of the clicking/vibrating. But on a shutter speed above 2 seconds, the image quality and everything else seems to be working normally.
I checked the shutter actuations on it (I thought it was higher) and its only at 23k
08-25-2011, 05:25 AM   #7
Stone G.'s Avatar
QuoteOriginally posted by Senseriffic Quote
Well, how did those original long exposures turn out? Were they blurred or just "fine"? And, if you try a "long exposure" the camera in your hand, would you actually feel any ever so sligth vibration in the body.
My (limited) experience is that old electrical apparatus can be a bit more noisy than when new. My K200D sometimes make a slght hissing sound during long exposures, but imáges are still perfect, (or, as perfect as the photographer behind the camera allows).
09-10-2011, 12:09 AM   #8
Always came out great before, and of course used a tripod. You can HEAR the vibrations/clicking. its very loud and noticeable. I still havent figured it out yet
camera, exposures, k100d, pentax, pentax help, pentax k100d
Landscape Long Exposures lls Post Your Photos! 7 08-17-2011 09:18 PM
Nature Long exposures at the beach ismaelg Post Your Photos! 8 04-20-2010 10:39 PM
Pentax 645 long exposures? tplew1 Pentax Medium Format 2 04-14-2010 04:57 AM
Cityscape Long Exposures attack11 Post Your Photos! 6 01-20-2010 01:49 PM
Pentax and long exposures ftpaddict Pentax DSLR Discussion 10 06-27-2008 11:27 PM
All times are GMT -7. The time now is 04:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
