08-22-2011, 01:27 AM   #1
K100D Super sensor problem
Hi, i have this problem in most of pictures from my K100D Super, there are darker stripes, mostly in shadow and midtone areas, as you'll see in the attached photo (100% сrop). Anyone had this problem? Seems to me that sensor is dying..
08-22-2011, 06:07 AM   #2
This picture lacks Exif info.
What ISO did you use here?
Bert
08-22-2011, 06:42 AM   #3
These lines are horizontal, (a picture is rotated). Exif info below:
Model: PENTAX K100D Super
Serial #:
Firmware: K100D Super Ver 1.00
Frame #: 1292
Lens (mm): 50
ISO: 800
Aperture: 1.4
Shutter: 1/90
Could it be that contacts between sensor and the main board need cleaning?
08-22-2011, 07:49 AM   #4
Banding should not be a problem at ISO 800 at all.
You can see the pattern also in the lighter areas.
Sure you did not cranck up an underexposed picture a lot in post processing?
Did you try another SD card?
If not, looks like a serious problem to me.
You are still on firmware release 1.0
For some camera's updating the firmware helped dealing with banding problems, but I've never heard of such thing with a K100D Super.
Sorry, Bert
08-24-2011, 07:28 PM   #5
Is any of this visible on the lcd at maximum magnification? What image format and software are you using?
Paul
k100d, pentax help, sensor
Pentax k100d Super back LCD display problem pisach Pentax DSLR Discussion 2 05-30-2010 10:31 PM
K100D Super Shake Reduction problem lochest Pentax DSLR Discussion 2 10-15-2009 08:38 PM
K100D super problem jdg Pentax DSLR Discussion 2 04-21-2008 09:42 PM
K100D sensor/exposure problem? LightBug Pentax DSLR Discussion 4 12-05-2007 09:10 AM
Automatic Sensor Cleaning in k100d Super and k10d superfuzzy Pentax DSLR Discussion 3 11-19-2007 04:18 PM
All times are GMT -7. The time now is 07:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
