08-24-2011, 08:57 AM   #1
Flash on a manual or a lens?
What kind of function will I get with the pop up flash or with external flashes with manual or a lenses? From what I gather, with manual lenses there will be no function at all (full power maybe) with the internal flash or an external flash. Is that correct? What about with an a lens? I haven't found as much info on that. I gather that it can meter since it has aperture information and therefor the flash should work correctly? How does zooming effect it?
If it matters, I have an ist-ds, and have several promaster modular flashes. I have control modules that are basic thyristor flashes that are not dedicated (would that work with a full manual lens)? I also have modules that are ttl (ist-ds can use ttl or p-ttl) and just acquired a p-ttl module (I am new to manual lenses and thought the p-ttl module was broken when I got it, then realized it was because it was a manual lens).
08-24-2011, 09:27 AM   #2
enoeske's Avatar
QuoteOriginally posted by ripit Quote
With K and M series lenses, the pop up flash will fire at full power. An external flash will default to M mode and you can choose what power setting it will shoot at.
With A and newer lenses, you get full p-ttl with both the pop up flash and external flashes (if they are so equipped)
Cameras newer than the *Ist D series do not have ttl capabilities and only have p-ttl.
08-24-2011, 10:05 AM   #3
Thanks for the info. With K and M series lenses, will a thyristor flash do any good? My flashes only have a couple of manual power settings so they are limited in that regard. They have a removable control module though, and I have the newer p-ttl control module, the older pentax ttl control module, and a generic single contact thyristor module (I also have slave modules but that's not really relevant here).
08-24-2011, 10:14 AM   #4
enoeske's Avatar
If the flash has its own light sensor (and an Auto mode) then it will work fine since that doesn't rely on communication with the camera. Use the setting guide on the back of the flash to set the camera settings and then leave the flash in A mode.
08-24-2011, 10:33 AM   #5
Yes it has its own light sensor on the thyristor module. Thanks again for the information. I'll have to play with it and see how sell it works with manual lenses.
camera, flash, flashes, function, ist-ds, lens, lenses, module, modules, p-ttl, pentax help, photography, ttl
Kr, manual lens and radio trigger flash - help! oakey1979 Pentax K-r 6 07-31-2011 12:56 PM
manual aperture lens + popup flash. 006 Pentax K-5 & K-5 II 2 03-11-2011 06:23 AM
k7 + AF360 Flah + Manual Macro lens = No wireless Flash? mgbirder Flashes, Lighting, and Studio 5 10-11-2010 04:01 PM
Using built-in flash on K100d with a manual lens seeker Pentax DSLR Discussion 2 04-18-2007 10:55 AM
Flash using Manual 50mm 1.4 lens Wildfire_ja Flashes, Lighting, and Studio 5 12-13-2006 08:10 AM
All times are GMT -7. The time now is 01:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
