08-24-2011, 11:31 AM   #1
hman's Avatar
My lens is missing something!
I just received a 28mm f/2.8 Auto Rokinon that I got on ebay for $8.00. Takes 52mm filter. Has green letters "KA", and a green "A" to the left of f/22. To the left of the green "A" is a hole where I believe there should be a button to lock "A". So, that suggests that aperture must be manually set. Other than that, looks pretty clean. Is my thinking correct? Is this something I can fix? If not, it's a very cool paperweight. Thanks in advance.
08-24-2011, 11:44 AM   #2
ChipB's Avatar
Well, even if you have to use it manually, I don't think it's a "paperweight".
Try setting the aperture ring to the "A" position, put the lens on your camera, set the camera in the "Av" position and see if you can control the aperture via the camera dial. If you can, then you're good to go - if not, then you've still got a pretty good deal at $8 for the lens.
One caveat - watch out for the dreaded "Ricoh" pin problem. Search this forum and you'll get lots of hits - some will have photos of the pin to watch out for and solutions.
Good luck.
08-24-2011, 12:23 PM   #3
hman's Avatar
Doesn't appear to have the Ricoh pin, based on the photos I have seen. Setting the aperture ring to "A" and setting camera mode to Av and AF switch does nothing- viewfinder says "MF" so looks like I have a fully manual lens for $8.
The missing "button" that locks "A"- is that DIY fixable?
Thanks for your help!
08-24-2011, 01:23 PM   #4
Of course the viewfinder says MF, it's manual focus! What matters is if you can set the f-stop from the camera or if the LCD says F-- (what it says when it doesn't know the aperture).
08-24-2011, 01:38 PM   #5
button fell out
QuoteOriginally posted by hman Quote
I suspect there was a plastic button in the A hole
I have heard of them falling out!
No problem. I suspect sticking a ball point pen or such into the hole and pressing in as you rotate the lens towards the A position will solve the problem.
Let us know please.
08-24-2011, 03:01 PM   #6
hman's Avatar
L33tGregg: loved your tone!
In any event, in Av mode with aperture set on "A" (easily moved out though), f stop can be set from the camera. So it's not that it won't work on "A", it's more like it may be hard to keep it there. Will try foreign object such as pencil to see effect of pushing.
Thanks all.
09-01-2011, 04:59 AM   #7
hman's Avatar
My lens is missing "A" button
What I need is something that will replace the "A" button so that I can lock it, and also unlock to allow use of aperture ring. Any ideas out there? Thanks in advance.
09-01-2011, 06:10 AM   #8
bdery's Avatar
You can probably disassemble it and replace it with some custom button. I suggest you google it, or search youtube. It's probably a relatively simple operation if you know what you're doing.
pentax help
Lens unlock button missing steve917 Pentax K-5 30 12-10-2012 09:41 AM
Lens unlock button missing Tired Old Man Pentax K-5 2 06-18-2011 07:06 PM
Lens from B&H missing warranty card vtqanh Pentax SLR Lens Discussion 5 06-14-2010 09:43 AM
EXIF Lens Model field missing for DA* 55 ridogi Pentax SLR Lens Discussion 5 03-29-2010 10:01 AM
lens comparisons - what am I missing? WMBP Pentax SLR Lens Discussion 16 09-08-2009 11:25 PM
All times are GMT -7. The time now is 07:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
