Originally posted by JinDesu I've heard a lotta reports of people getting motion sickness with lens IS..
I suffer some sort of "sickness" when I stare for a long time through the VF with OS enabled (like when Manual Focusing in Low Light or for the heck of it) on close focused objects (say a Coffee cup on a table edge with the rest of the table fanning out in view to the distant wall) .... But 'normal' use is fine.
I also put sickness in quotes - because I don't suffer anything anywhere else that I can compare it to - but I'm lead to believe its most likely the equivalence of motion sickness....
Anyway - ok in short doses - does start making you feel giddy after prolonged staring at *close* objects depending on field of view.... (doesn't seem to happen when viewing distant ones - or if looking straight down on an object with a background that fills the VF)
