08-27-2011, 08:43 PM   #1
rlatjsrud
Guest
water proof.
I have K-5 and 16-50 lens.
I want to check the water proof.
If I put some water on the K-5 and lens, it still safe?
08-27-2011, 08:46 PM   #2
Digitalis's Avatar
pentax cameras and lenses are designed to be water resistant - not water proof: there is a big difference between those terms. You can dunk a water proof camera in a bucket of water without a problem, but a water resistant camera isn't designed to be immersed. Though having said that I have used hundreds of cameras over the years in moderate downpours and I haven't experienced any major catastrophic failures....... yet.
08-27-2011, 08:52 PM   #3
noblepa's Avatar
As Digitalis points out, Pentax claims that the K-5 and lens are weather resistant, not water proof.
There is a video out there of someone holding a K-7, I believe, under a shower. The camera survived the experience, apparently none the worse for wear.
Why do you want to "check the water proof", anyway? If the camera does not survive, the damage will not be covered by the warranty. Are you willing to risk over $2,000 on this experiment?
I have a K10D, which is also weather resistant, although the kit lens is not. I still try to avoid getting it too wet or dusty. I look at the WR as a little extra insurance for those times when I can't avoid a little rain or dust, not as a challenge to see how far I can push the limit.
08-27-2011, 10:35 PM   #4
RioRico's Avatar
Why do you want to check for waterproofing / weather resistance? Do you plan to shoot in or under water? If so, it is much safer to use an actual underwater camera, like a Pentax Optio W90 or W80. My K20D is WR and some lenses seal very tightly, but I keep them well away from water -- I won't risk them! When I get wet, it's with an Olympus 770-SW which is rated to 10m / 33ft depth underwater. Or if I'm shooting in torrential rain, I wear a wide-brim hat and keep the camera in a plastic bag.
"Testing waterproofing" can be very expensive. My recommendation: DON'T DO IT!!!!
08-27-2011, 11:31 PM   #5
hcc
hcc's Avatar
+1 with all previous posts.
WR =weathe resistant: "weather sealed and coldproof design resists water, fog, snow, sand, dust, and more" (Pentax website).
WR is NOT waterproof.
Please do take care of your gears.....
08-28-2011, 06:28 PM   #6
Ex Finn.'s Avatar
On should be fine, in, is not such a good idea.
If it gets rained on. it should be ok. Just do not dip it in a pool.
IRENE was here!.
08-28-2011, 06:34 PM   #7
twitch's Avatar
WR, "weather resistance" should be treated as insurance not as the first line of defence. If you have car insurance you don't crash your car into a wall to test the insurance pays out.
So don't "test" it, don't even count on it 100%, just just be happy if your gear gets a bit wet it should be OK.
08-30-2011, 08:47 AM   #8
TER-OR's Avatar
I accidentally spilled water over my K5 and FA100 the other day. So far no problem, but I'm leaving the lens out to hopefully prevent any problems. It doesn't appear to have any water inside, but upon rolling the focus out and in it did track water with it. Let's hope the build quality holds up and saves me...it's a nice lens and I don't want to have to replace it. No issues with the camera, I just cleaned the exterior as best I could - it wasn't clean water...
08-30-2011, 05:34 PM   #9
Ex Finn.'s Avatar
I avoid zooming in and out when in a heavy down-pour.
"I want to check the water proof."
It is ok, no need to check any further.
08-30-2011, 06:17 PM   #10
I think it's unwise to let the camera get as wet as seem to have gotten it, apparently just for amusement. I've gotten my K200d wet, too, but try to cover it with a plastic bag, mostly keep it under an umbrella, etc. I treat it about the same as my non-WR K100d. The K100d got some water under the top lcd once, but it went away after some blowing with a hair dryer. The point is that at some point it's possible water will do some damage. It probably wouldn't kill you to help your expensive camera out by putting a plastic bag over it with a hole cut out for the lens.
What I find is that when the rain gets heavy enough to possibly be harmful to the camera, it's impossible to keep my lens clean, no matter how deep the hood. At that point I usually give up, but I don't just carry the camera home out in the open because I (supposedly) can.
Paul
08-31-2011, 02:33 PM   #11
Ex Finn.'s Avatar
QuoteOriginally posted by tibbitts Quote
Maybe I need an excuse to get a K5.
Believe me, If i had had any doubts about the seals, the camera would have stayed in the house ( 50 mph winds and 14 inches of rain from Irene, not as bad as Isabell thou).
p.s. That 16-50 hood does a fantastic job in keeping the front element dry.
08-31-2011, 03:08 PM   #12
amoringello's Avatar
First thing I do with any new WR camera and/or WR lens is put it in the shower and put it through it paces.
I take my camera just about everywhere and if its raining, I do not want to stop shooting.
Was recently on vacation and the weather was awful. As everyone else put their cameras away, I was the only one with photos.
Maybe not the best photos, but I had them. :-)
I want to make sure I don't have a dud and make sure that I can take it back before the bad weather comes. :-)
I've been out in torrential downpours (stronger than my shower). Both the camera and lenses hold up just fine.
Just head the warnings of water-proof v.s. water-resistant.
Also, be sure to rinse well if you're near salt-water!!
08-31-2011, 03:29 PM   #13
Ex Finn.'s Avatar
Coming up on first 8 inches.
My thinking is that if You have a weather sealed body and a lens, why not use the advantage.
It is a tool and yes, tools can fail but being too careful takes all the fun out of it.
08-31-2011, 03:53 PM   #14
Ex Finn.'s Avatar
17 minutes later, going past the 8 inch mark.
So glad to have access to a weather sealed body that is within my means.
08-31-2011, 05:11 PM   #15
Lowell Goudge's Avatar
there is an old post around here from a new (at the time) K7 owner who complained that after the 50th washing under his kitchen tap, his K7 failed. His practice was to wash off the camera after every use.
As others have said, although the camera is weather resistant, it is not water proof, and you should treat this as insurance not the primary protection.
can cameras get wet and survive, yes, in fact I have an *istD that got swamped in a Kayaking spill in 2004, after drying it out, it is still working today. ANd it is not weather resistant.
BUT if you intend to do a lot of foul weather shooting, use a weather bag, and rely on the WR body and lenses to keep you safe if the bag fails, or if you get caught.
Dont soak the camera just to see what it can withstand, it will only prove one thing, a fool and his money are soon parted, because somewhere, I am very sure, there is a disclaimer about abuse in the warranty clauses
camera, k-5, lens, pentax help, photography, water
Nature One of the last proof of autumn SebastianP Photo Critique 12 11-30-2010 08:20 AM
Macro Proof that Mantids are patient arpaagent Post Your Photos! 2 06-01-2010 08:08 PM
weather proof? jolee1990 Troubleshooting and Beginner Help 5 05-24-2010 04:39 AM
Is FA 77mm Ltd. weather-proof? braver Pentax SLR Lens Discussion 3 03-01-2010 04:49 PM
Which weather proof camera? Mallee Boy Pentax Compact Cameras 9 09-26-2009 09:44 AM
All times are GMT -7. The time now is 11:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
