08-30-2011, 08:03 PM   #16
Great replies! Thanks!
OK, it seems I screwed up. I got the lens via UPS yesterday and rushed out to snap pictures of everything on my property! (Has anyone else ever done that??? haha.) It seems that after more careful testing the flash shadow goes away after 35mm or more. At 18mm the shadow is very bad. At 20 still bad. 25 not as bad. 30 barely noticeable, and 35 its gone completely. After 35 nothing wrong. So I think I can work with this. Im totally confused now though. I originally noticed this at 18mm. I assumed that the length of the lens was the issue. (I ran into this same issue with one of those cheap ebay super wide angle adapters.... but thats another thread.. be watching for it.) I would have assumed that the length of the lens was the issue. But it's not. That seems backwards to me. It gets worse at super wide angle. Can anyone explain why that is?
Thanks!
08-30-2011, 09:35 PM   #17
yeatzee's Avatar
the onboard flash itself does not have a wideangle "add-on" like a decent speed light does to reach those wider angles. Alone it cannot even get close to doing 18mm worth of coverage
08-31-2011, 09:38 AM - 1 Like   #18
QuoteOriginally posted by SelfEmployedDebtFree Quote
Great replies! Thanks!.....ts gone completely. After 35 nothing wrong. So I think I can work with this. Im totally confused now though. I originally noticed this at 18mm. I assumed that the length of the lens was the issue. (I ran into this same issue with one of those cheap ebay super wide angle adapters.... but thats another thread.. be watching for it.) I would have assumed that the length of the lens was the issue. But it's not. That seems backwards to me. It gets worse at super wide angle. Can anyone explain why that is?
Thanks!
Both lens physical size and focal length are issues; Here's an illustration of what's going on...
If the lens is bigger (either longer or fatter) the shadow will be bigger.
If the flash is moved up the shadow will be smaller.
If the focal length is long the shadow won't be seen.
if the focal length is short the shadow may be seen - the wider the lens angle, the greater the potential problem
It gets worse when the ground is considered. I added a ground plane to the above illustration showing how the flash shadow can easily show on the ground in front of you. It gets even worse if the camera is tilted down, so if you need to take a short focal length flash photo of a child, kneel or squat to avoid getting the ground in the photo.
Hope this helps...
09-01-2011, 09:17 AM   #19
Yes. That really explains it perfectly. Common sense actually now that you see the diagram.
09-06-2011, 05:27 PM   #20
GerryL's Avatar
Just get one of those third party off-camera flash cords.
Costs less than $20 and it should take care of the shadow problem.
camera, day, disney, flash, lens, light, night, pentax help, photography, picture, shadow, tripod
keep/avoid flash shadow w/single flash danielchtong Pentax DSLR Discussion 2 05-09-2010 05:29 PM
A new low - ugly lens Nesster Canon, Nikon, Sony, and Other Camera Brands 9 01-23-2010 10:11 AM
For Sale - Sold: AF280T flash/ugly duckling wildlifephotog Sold Items 3 09-18-2009 10:54 AM
Shadow created by lens photomad_2007 Pentax DSLR Discussion 8 04-01-2008 05:03 AM
Ugly ducks with the ugly duckling lens rfortson Post Your Photos! 3 03-01-2007 03:43 PM
All times are GMT -7. The time now is 11:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
