09-01-2011, 12:20 AM   #1
SD Card image recovery
I had a PC wobbly which is fixed, but it happened just as I finished transfering a few images from the camera and deleted the files on the card.
A recovery program (Ease US) got the images off the card for me - but without the EXIF...
Has anyone used a program that has managed to get the EXIF as well as the image?
09-01-2011, 12:33 AM   #2
hcc
hcc's Avatar
I use Recuva (Recuva - Undelete, Unerase, File and Disk Recovery - Free Download) to recover damaged files and I can recommend it.
However I do not remember that it recover EXIF.
Hope that the link may help.
09-01-2011, 01:10 AM   #3
Thanks, top tip.
It got them back with the correct names and the EXIF, and just the ones taken last time - the other utility (ZAR) spend a long time scanning the card and found all the intact files on it. All I had to do was tweak the search pattern to include .pef.
Suspect a deep scan with Recuva would have found everything on the card.
09-01-2011, 02:28 AM   #4
hcc
hcc's Avatar
QuoteOriginally posted by cats_five Quote
Well done. I am genuinely glad that you recovered all.
I have used Recuva many times. In some bad cases of corrupted cards, I could not always recover all.
I might suggest that you reformat your card once you recovered all your shots.
09-01-2011, 02:54 AM   #5
Was going to reformat the card but since it was a PC wobbly it's probably not really necessary - the files Recuva got were perfect, just deleted!
There does seem to be a big varience in the quality of recovery software though and none of them seem to document the things they will try to recover for each file type.
09-01-2011, 01:13 PM   #6
Canada_Rockies's Avatar
When you are sure that you have recovered every image that there was, format the card IN CAMERA. The PC is a lot more forgiving than the camera when it comes to formatting. Once I have transferred files to my two hard drives, I format the card in the camera. I have had no card problems in almost four years now.
09-01-2011, 11:23 PM   #7
I haven't had any card problems ever - so far! It was that the PC had copied the files down, deleted them from the card and then lost them that lead me to Recuva. I do know to format my cards in the camera, and I never use reformat as a way of deleting images - Bridge does that perfectly well. And I don't normally take the cards out of the camera either, I plug the camera in with the USB cable. Saves forgetting to put the card back in the camera...
09-02-2011, 08:23 AM   #8
I don't delete the images after import. I simply format the card in camera after I know all the images are on my two (2) USB drives. My PC only copies the images; it does nothing else with the card - read only is the trick here, I think. I never delete images, period. Holdover from old PC days where the files system could get screwed up if one deleted from floppy disks sometimes.
09-02-2011, 10:16 AM   #9
I have always deleted after import and it's never caused me any problems until the PC decided to throw a wobbly, but Recuva sorted it all out for me.
09-07-2011, 12:06 PM   #10
I have used a free program called Restoration that also saved the exif data from deleted images.
card, image, images, pentax help, program, recovery
card recovery software adwb Photographic Technique 9 12-20-2010 10:00 AM
underexposure recovery kenyee Pentax Medium Format 2 09-24-2010 05:20 AM
Deleted Image on My Memory Card mattmiles Troubleshooting and Beginner Help 3 01-17-2010 02:00 AM
For Sale - Sold: SanDisk Rescue PRO Data Recovery Software for Memory Card - NEW Genes Pentax Sold Items 0 12-08-2008 10:19 PM
RAW PEF file recovery from corrupt SD card mcpieman Digital Processing, Software, and Printing 0 09-29-2008 07:53 AM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
