09-05-2011, 12:03 PM   #1
Is it compatible to K-r?
hello felows, I need a tip. I would like to know if Kenlock F=100-300mm lens is compatible to pentax k-r. does anyone know it? thanks in advance
09-05-2011, 12:21 PM   #2
Is it a K-mount lens? If so, then yes. Otherwise no. If possible, could you post a picture of it?
09-05-2011, 01:58 PM   #3
[langtitle=pt]kenlock 100-300mm[/langtitle]
Hi Adam, thanks for answering. this lens has been offered in a site like ebay here in Brazil. In the last pic you can see that is part of Yashika machine set. but we can't see the diameter of the lens.
09-05-2011, 01:59 PM   #4
hcc
hcc's Avatar
On the 3rd shot, you should take off the cap to show the mount.
09-05-2011, 02:01 PM   #5
The bayonet is hidden on you pictures, but the bayonet cover says CO-Y. Contax-Yashica. Sorry, it won't fit directly. Maybe you can find a way to modify it.
09-05-2011, 02:05 PM   #6
yes Cid, the lens come with an old Yashika machine! tx
09-05-2011, 05:30 PM   #7
RioRico's Avatar
The lens will not fit a Pentax camera. The lens bayonet could be modified to fit, but that is not really a good idea because of the lens' weight. And this very slow (f/5.6) lens is not really worth modifying, not unless you are absolutely desperate! I think you should look for a lens that will actually fit your Kr. Good luck!
Is this compatible with the K-x? Loli Troubleshooting and Beginner Help 4 04-05-2011 02:11 PM
Compatible lens for K-x amitincal Troubleshooting and Beginner Help 12 02-17-2011 05:08 PM
K-r compatible with Sigma 24-60 f2.8? theokaluza Pentax K-r 5 02-09-2011 06:39 PM
Any of these worth getting? Compatible with K-x? CrossStealth Troubleshooting and Beginner Help 5 02-14-2010 07:58 AM
need help are all k mounts compatible autosri Troubleshooting and Beginner Help 7 11-15-2009 11:04 AM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, part of our network of photo forums!
