09-06-2011, 06:32 PM   #1
*istDS Color distortion after few long exposures
All,
I am noticing color distortion on pictures. Especially, white color becomes pinkish. I have taken three long exposures (120 seconds - 164 seconds) before this started happening. Though I am suspicious I am not sure if I have burned the sensor. Is 164 seconds exposure at f/8 too much? Any ideas?
Thanks in advance.
09-06-2011, 06:38 PM   #2
Ole
Ole's Avatar
It would help if you posted an example. Without it we're shooting in the dark
Anyway, let me take a shot in the dark: Earlier DSLRs had a problem with some circuitry mounted near the sensor becoming hot during long exposures and that would affect the sensor and lead to color casts. These color casts would typically be at an edge or a corner, and not affect the entire frame. The color cast would go away when the circuitry cooled down, in other words, no permanent damage.
09-06-2011, 06:45 PM   #3
Here are the pictures. Thanks.
09-06-2011, 06:57 PM   #4
Wheatfield's Avatar
That almost looks like a colour space problem. I don't suppose you could post something with the exif data intact?
09-06-2011, 07:42 PM   #5
Exif Data for Picture 1:
exif:ColorSpace: 1
exif:ComponentsConfiguration: 1, 2, 3, 0
exif:Compression: 6
exif:Contrast: 0
exif:CustomRendered: 0
exifateTime: 2011:09:06 18:40:37
exifateTimeDigitized: 2011:09:06 18:40:37
exifateTimeOriginal: 2011:09:06 18:40:37
exif:ExifImageLength: 2000
exif:ExifImageWidth: 3008
exif:ExifOffset: 602
exif:ExifVersion: 48, 50, 50, 49
exif:ExposureBiasValue: 0/10
exif:ExposureMode: 1
exif:ExposureProgram: 1
exif:ExposureTime: 1/90
exif:FileSource: 3
exif:Flash: 16
exif:FlashPixVersion: 48, 49, 48, 48
exif:FNumber: 63/10
exif:FocalLength: 250/1
exif:FocalLengthIn35mmFilm: 375
exif:InteroperabilityIndex: R98
exif:InteroperabilityOffset: 52242
exif:InteroperabilityVersion: 48, 49, 48, 48
exif:ISOSpeedRatings: 200
exif:JPEGInterchangeFormat: 52368
exif:JPEGInterchangeFormatLength: 2594
exif:Make: PENTAX Corporation
exif:ResolutionUnit: 2
exif:Saturation: 0
exif:SceneCaptureType: 0
exif:SceneType: 1
exif:SensingMethod: 2
exif:Sharpness: 0
exif:Software: *ist DS Ver 2.02
exif:SubjectDistanceRange: 1
exif:WhiteBalance: 1
exif:XResolution: 72/1
exif:YCbCrPositioning: 2
exif:YResolution: 72/1
Exif Data for Picture 2:
exif:ColorSpace: 1
exif:Compression: 6
exif:Contrast: 0
exifateTime: 2011:09:06 18:40:25
exifateTimeDigitized: 2011:09:06 18:40:25
exifateTimeOriginal: 2011:09:06 18:40:25
exif:ExposureTime: 1/180
exif:FileSource: 3
exif:Flash: 16
exif:FNumber: 45/10
exif:FocalLength: 39/1
exif:FocalLengthIn35mmFilm: 58
exif:JPEGInterchangeFormatLength: 5490
exif:MeteringMode: 5
exif:Model: PENTAX *ist DS
exif:Orientation: 1
exif:Saturation: 0
exif:SceneType: 1
exif:Sharpness: 0
exif:SubjectDistanceRange: 2
Profile-exif: 57868 bytes
09-07-2011, 05:54 PM   #6
Ole
Ole's Avatar
Is the camera now also defect at normal shutter speeds?
Which white balance setting did you use?
I suspect that your camera is defect. It could look as if a color channel is missing and/or white balance is way off. Perhaps it overheated when you did the long exposures.
09-07-2011, 08:26 PM   #7
I have used both Cloudy and Auto with normal shutter speeds and the results are same. Is it a common/known problem with *ist DS when long exposures are used? Not sure if I should send it across to Pentax service center for repair. They seem very expensive.
09-08-2011, 04:21 PM   #8
Ole
Ole's Avatar
I don't know if this is a common problem. A repair probably doesn't make sense. You could check the market place on the forum for a second hand newer body, or perhaps look for a new K-x (discontinued but might still be available for a reasonable price) or K-r.
color, distortion, exposures, pentax help
Landscape Long Exposures lls Post Your Photos! 7 08-17-2011 09:18 PM
Best ISO for long exposures... richardm Troubleshooting and Beginner Help 2 01-12-2011 07:01 AM
Getting into Long Exposures - Which ND Filter? jaieger Pentax Camera and Field Accessories 10 12-04-2010 11:13 AM
Nature Long exposures at the beach ismaelg Post Your Photos! 8 04-20-2010 10:39 PM
Cityscape Long Exposures attack11 Post Your Photos! 6 01-20-2010 01:49 PM
All times are GMT -7. The time now is 05:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
