09-11-2011, 02:34 PM   #1
Image looks like a polarising filter was used
For some reason a set of my photos (80+) appeared to have been taken through a polarizing filter - see example. All of these photos were taken on an infield tour at an airport on a very sunny day around the noon hour. I shot from a car through an open window using a Pentax K-x and kit 18-55 lens, no filter. A clue might be that I put a fresh memory card in and noticed later that instead of it being an SDHC it was a plain old SD. No problem with my other card before. All these photos were saved on the plain SD card. Any reason why there should be such a darkening of the sky? One problem for me is that the video on my computer is acting up and I see a lot of graduation lines in the sky instead of a smooth gradient, so I am not sure if that is a fault as well.
09-11-2011, 03:12 PM   #2
wshi's Avatar
Check your histogram. All it looks like is you've underexposed by quite a bit.
09-11-2011, 03:16 PM   #3
Do you ave highlight / shadow correction on? That could mess with your exposure in an attempt to avoid blown highlights or blacked out low-lights.
09-11-2011, 08:33 PM   #4
grog85361's Avatar
The EXIF data shows -0.7 EV. This would explain some of the underexposure.
09-11-2011, 08:53 PM   #5
Wheatfield's Avatar
I just brightened it with levels, and it looks fine. I think it's just underexposed.
09-12-2011, 09:31 AM   #6
Thanks, all. I DID quickly notice while shooting that the histogram was on the dark side, but there was so much going on (I got a chance to be in a three-car police-led convoy across the secure side of an airport) I didn't want to look down and change settings. It was when I looked at these images on my primary computer they looked real bad. Now I've looked at them on another computer they are not so bad. On my bad computer the deep blue sky wasn't a smooth gradation but a series of bands or steps from almost black at the top. I was just looking for an excuse for a new computer.......
09-12-2011, 10:36 AM   #7
Philoslothical's Avatar
QuoteOriginally posted by kitkat Quote
Sounds like that computer is set to display 16 bit colour. Switch it to 32 bit and you should see a huge improvement, although it won't fix any brightness or contrast issues - you'll need to adjust them separately, either through buttons on the monitor, or software that came with your video card (or both).
09-12-2011, 05:55 PM   #8
It is set to 32-bit. There are other video issues as well but this is a new issue.
09-12-2011, 06:10 PM   #9
Well, it was worth checking. Lowered colour depth is the most common cause of that kind of banding/pixelation effect.
You might also want to check and possibly replace your monitor's cable, if possible.
09-13-2011, 08:32 PM   #10
SpecialK's Avatar
QuoteOriginally posted by Philoslothical Quote
I had a "sky banding" issue and it was solved by a new cable.
card, filter, pentax help, photos, reason, sd, sky
Image rotation when reviewing image. Worked on K7 but not K5? crossover37 Pentax K-5 23 11-21-2012 09:32 PM
Wanted - Acquired: 49mm linear (not circular) polarising filter stillshunter Sold Items 0 08-19-2011 04:00 AM
Polarising filter for Pentax DA limited catastrophe Pentax Camera and Field Accessories 11 09-23-2010 08:17 PM
Polarising Filter timk Pentax SLR Lens Discussion 15 08-15-2009 05:18 PM
All times are GMT -7. The time now is 10:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
