09-12-2011, 08:01 AM   #1
PENTAX AF 240FT AF Assist beam / spotbeam
Will the flash and this feature work on K20D? Can the assist beam be used without flashing?
09-12-2011, 08:17 AM   #2
Just1MoreDave's Avatar
The TTL part won't work. The flash will always fire at full power. This flash has a switch that manually sets it to 1/4 power, and that's the only power adjustment you have. The flash doesn't have its own light sensor so it's not like the AF280T, which will cut off power if it thinks there was enough. Voltage is safe. The spotbeam will work fine. There's a switch to use just the spotbeam, which will disable the flash. The manual says the spotbeam range is 6 meters. I have the manual if you have more questions. It doesn't mention the K20D.
09-12-2011, 10:03 AM   #3
No TTL on K20D
I'm thinking to get the AF assist from this flash, so no problem I guess.
09-13-2011, 11:47 AM   #4
I'm not sure about your part of the world, but if you need just the AF assist, you may want to look for a Metz SCA 374/2AF. When used by itself, it acts as an AF assist, powered by 4 AAA battery cells.
A good used copy is US$ 15 - 20 here.
Note: the AA battery cell in this photo is only for scale.
09-13-2011, 04:51 PM   #5
minahasa,
your question seems to be present in 2 threads. I had answered here:
https://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/158583-...-spotbeam.html
af, af assist beam, assist, beam, camera, pentax help, photography
PENTAX AF 240FT AF Assist beam / spotbeam minahasa Flashes, Lighting, and Studio 1 09-13-2011 04:40 PM
External Flash AF assist Beam Dionisis_K Pentax K-5 3 08-03-2011 11:02 PM
Pentax 360FGZ help... Focus assist beam??? Senseriffic Pentax Camera and Field Accessories 3 03-06-2010 02:04 AM
AF assist beam for K10D Nvision_Ink Troubleshooting and Beginner Help 5 06-30-2009 09:47 AM
Shouldn't they invent a focus-assist-beam accessory for the hotshoe? aweir Pentax Camera and Field Accessories 11 04-01-2009 04:52 PM
All times are GMT -7. The time now is 07:58 PM. | See also: NikonForums.com, part of our network of photo forums!
