Originally posted by Just1MoreDave The only reason I can think of to skip the DA 21 is how it integrates into a set of primes. It might be a little close to the DA 15. My choice would be something like 15-24-35-55-85-120, but Pentax needs to make a few more lenses to make that work, and I might need money.
What he said. I started out to build essentially that kit, except that there isn't anything affordable in AF at the 55 or 85 focal lengths, so instead I have an FA 50/1.4, which effectively becomes an 85mm with the teleconverter attached.
On the other hand, if you aren't drawn to the DA 15 (i.e. it hasn't controlled your mind :-) ), then DA 21- DA 35 - DA 70 is a nicely spaced kit, and a very small one . . .
