Originally posted by zerotonothing 1) What systems do you use for the filing and organisation of negatives and their respective prints? I have about 20 sets of negatives, I want a filing system to match the prints with their negatives. So when a print gets separated from it's negative, it can be matched again.
The most obvious answer is marking the back of the print with a marker/pen, but I've found the writing either dissolves or indents through the other side. I was thinking to write on stickers, then stick them on. What do you use?
2) I have a lot of exposures which are out of focus. When shooting them, they appear in focus. This is on a 50mm f1.7. I'm guessing due to the aperture being wide open, this out-of-focus thing is actually an extreme and unwanted DOF issue. On my last roll I stopped down to 2.8 on some photos and it seemed to solve it. Does this sound right? I'm shooting street photography at night, so I need it reasonably wide open.
Pentax "ME" Super
Thanks!
I have over time taken about 15,000 prints. they are all separated at this point from the negatives, but.....
I store the prints in an envelope which I have put the processing lab negative number on, and store the negatives in a binder in archiving sheets, by processing batch number. I also have them all SCanned and stored by Processing batch number, and use the processing batch number in the filename prefix.
That way, I can, if I want, look at a print, check the envelope, and go to either the negative or the computer and find the shot. If I find, by looking at photo's that there is a mark, dust etc, that impacts my scan, I can re-scan the negative, or modify the scan settings etc, to get a better copy.
I now, don't really look any more at prints, because I have
EVERYTHING I HAVE EVER SHOT digitized. It was a 5 year project, and covers 15K negative images and 5K slide images.
I have the images sorted based upon the negative processing numbers, and also by year and month (or activity)
