Originally posted by littledrawe Would a lens made for the the pentax film SLR with a focal length of 35-135 be the equivalent of the DA 50-200 currently produced if the crop factor is applied to the older lens?
Moving a lens to a different camera does not change its focal length. Moving a lens to a camera with a smaller frame (film or digital) crops a smaller portion of the projected image, hence the term crop-sensor. Moving a lens to a camera with a larger frame records a larger portion of the projected image. The frame size determines the FOV produced by by any given focal length.
An 18-55mm lens on APS-C has equivalent FOV as a 28-80mm lens on 135/FF.
A 35-135mm lens on APS-C has equivalent FOV as a 50-200mm lens on 135/FF.
Unless you're an experienced 135/FF photographer who is transitioning to APS-C or 135/HF, forget that you ever heard of crap.factor. Just use your lenses and learn what each focal length does on each camera. Back in the day, I sometimes shot 135/HF and 135/FF and 6x6/MF and 9x12/MF on the same day, sometimes with the same lens. My colleagues and I never referred to crap.factor; the term hadn't yet been invented by a marketing wonk. We just learned our lenses. It ain't hard.
