09-24-2011, 05:01 AM   #1
K7 Manual Mode AE-L annoyances
Afternoon,
I'm new to photography and bought a Pentax K-7
The problem i'm having, and i'm sure its just a setting i'm overlooking, is in manual mode.
When i'm adjusting shutter speed and aperture the AE-L symbol locks on, from there on if i adjust the shutter speed it changes the aperature as well (i can cancel this by pressing the AE-L button, but it does it constantly)
Obviously this gets annoying when i want to stick with either the shutter or aperature i had set!
Hope this makes sense, any ideas?
Ta
Phil
09-24-2011, 12:02 PM   #2
Ole
Ole's Avatar
Check custom function 5 ("AE-L with AF locked"), it should be set to "1 (Off)".
09-24-2011, 12:19 PM   #3
Just1MoreDave's Avatar
If my camera is doing that, I have not noticed. That would be bad.
Check Custom Setting 1, #5, AE-L with AF Locked. If it's on, turn it off. That's the only suggestion I have from reading the manual.
09-25-2011, 11:14 AM   #4
Yup, she's set to 1!
Still does it!
If i set an aperature of say 4.5 then scroll the shutter dial it displays the ae-l symbol then starts moving the aperature i set...
Doing my head in now
09-25-2011, 02:54 PM   #5
My K-7 doesn't do this, and further reading of the manual suggests it shouldn't be happening.
If it was a stuck button, it would lock exposure in many other modes, except for modes like Bulb and X, so you could check that.
There's two options in the menus to reset to the default settings. One is in [Set-Up 3] and the other is in [Custom Setting 6].
It's not a problem listed in any firmware updates but that's my last desperation idea.
09-26-2011, 12:06 AM   #6
It definatly only does it in M mode. It will let me scroll through a few shutter speeds, then locks on moving the aperature until i press the damn button. It will literally do it 5 or 6 times moving from say 1/1000 to 1/30
If i try a reset and a firmware update and it still does it, i guess it should go back to Jessops then?
Do i explain the problem well enough, or will they mock me
09-26-2011, 10:50 AM   #7
Right, just updated firmware from 1.00 to 1.11, made no difference
Here's a little vid to demonstrate (appologies for how crap it is, phone camera)
You can clearly see the AE-L symbol flash when operating nothing but the shutter wheel, the the aperature changing
09-26-2011, 01:39 PM   #8
It must be returned then. The problem seems clear to me; maybe have the manual out to show the store clerk how it's not supposed to do that, or compare to a demo model? I remember returning my P3n because when I tightened the tripod screw, the camera stopped working. The first clerk said not to tighten the tripod screw.
09-26-2011, 03:42 PM   #9
Ex Finn.'s Avatar
As long as you do not suffer from "fat thumb syndrome", the camera must be messing up. Get an other one.
12-01-2011, 09:17 AM   #10
Just so everyone knows, i returned my K7 and its been repaired, they replaced the whole e-dial electronics i'm told.
Very odd!!!
04-06-2014, 12:36 PM   #11
QuoteOriginally posted by 2002gimp Quote
Afternoon,
Ta
Phil
Was this really a problem that was repaired? According to page 109 of the K-7 manual what you are described is normal operation. See attached screen shot. Perhaps I misunderstood the problem?
04-06-2014, 05:55 PM   #12
QuoteOriginally posted by spnny1 Quote
Zombie thread warning!
ae-l, aperature, camera, mode, pentax help, photography, shutter
ev adjust in manual mode on k-x DSNAPP Pentax DSLR Discussion 12 01-21-2010 03:30 PM
Suggestion Translation annoyances emr Site Suggestions and Help 3 12-15-2009 11:56 AM
ISO in Manual Mode campdog Pentax DSLR Discussion 4 11-24-2009 12:29 PM
Manual mode being difficult trishytee Photographic Technique 9 10-29-2009 04:31 AM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
All times are GMT -7. The time now is 07:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
