09-25-2011, 06:00 AM   #1
patrick9's Avatar
loose lenses on dslr
I have 3 manual lenses. Each one is a little loose on my *istDL I assume because of lack of electrical contacts. The 80-200mm is barely loose almost as tight as it ought to be. The 50mm is a little looser and the 135 is fairly loose. not enough to let light in but still loose.They all fit snug on my slrs .
My question is does anyone have an idea on a shim to snug the lenses up.that would last. I am only talking 1or 2 mm thick bout the thickness of the cardboard back to a note book or probably even thinner for the 135mm and about half that for the 50mm. I like using these but hate the wiggle they have on the DL
Thanks for any help
09-25-2011, 08:55 AM   #2
RioRico's Avatar
I use bits of inexpensive metal-duct tape on some lens bases to safely short the contacts to enable CIF. The tape is maybe 0.5mm thick; a couple layers should shim you out nicely. I bought a lifetime-supply roll of this tape at a not-cheap hardware store in a resort town for about four bucks; it ain't costly. Just be sure to get the shiny metal kind.
09-25-2011, 10:09 AM   #3
patrick9's Avatar
Thanks I had not thought of duct tape. I have some of the metal (shiny) kind already .
09-25-2011, 11:07 AM   #4
Mike Cash's Avatar
I have nothing useful to add. I just wanted to say how refreshing it is to see somebody who knows the difference between "loose" and "lose".
I've gotten so used to the ubiquitous error that at first I actually read your title as "Lose lens on DSLR".
09-25-2011, 11:17 AM   #5
RioRico's Avatar
QuoteOriginally posted by Mike Cash Quote
I have yet to lose a lens on a SLR. An entire outfit, yes, but not just a lens. Whew.
09-25-2011, 11:49 AM   #6
altopiet's Avatar
If it may help, I made myself some shims from used soft drink cans (just remove the paint from the outside with some fine sand paper). On this Cunor, I have to use 2.
09-26-2011, 07:34 PM   #7
patrick9's Avatar
It's funny how things taught years ago in school tend to stick . This was drilled in as was the difference between to and too. The later ones I see often . Use to drive me nuts.
This looks like I may need to try making a couple of these tomorrow
50mm, lenses, pentax help
My Pentax DSLR makes a rattling noise - is it defective? Something is loose inside! Adam Maintenance and Repair Articles 4 01-18-2013 08:02 AM
Which DSLR would you use with my lenses? BikerBry Troubleshooting and Beginner Help 9 08-26-2011 05:45 PM
Best DSLR for old lenses jt_cph_dk Pentax DSLR Discussion 11 04-08-2011 10:36 AM
31mm - How loose is too loose? mmphilip Pentax SLR Lens Discussion 5 07-31-2010 02:34 PM
old lenses and DSLR nelsh Pentax DSLR Discussion 5 06-18-2010 09:01 AM
All times are GMT -7. The time now is 08:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
